Highlighted posts from Monday, Aug. 29, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
August 29, 2022 * 19 posts * 184 views
ttocs said: shoot when I was in Az someone posted a set of black bullet deep dish wheels that were brand new, still had the plastic on the center caps and nubs on the wheels. The guy had a ... Read more >>
August 28, 2022 * 4 posts * 27 views
SN95_Project said: Hi guys. My son "kissed" a curb a couple days ago and took a chunk out of a new tire sidewall. Pic attached. You can see the width of it pretty good. Depth is probably 1/16-3/32. ... Read more >>
August 28, 2022 * 38 posts * 407 views
BHernandez said: I think your chasing a ghost. At this point, whatever it is hasn't caused enough damage to be discovered. Get out an enjoy it. When it starts to cause an actual problem, you'll ... Read more >>
August 28, 2022 * 11 posts * 163 views
Monday said: Is there an old chip still in your computer? You should go over your MAF, but I'd check the computer as well. Capacitors in particular. I can't say enough on those capacitors. ... Read more >>
August 29, 2022 * 1 post * 9 views
Warhorse Racing said: I've posted a lot of autocross driving & tech tips, but I haven't posted many run videos & results. I figured I would start sharing my results videos to help inspire more people ... Read more >>
August 29, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Why did the tire size change from 255/45 to 245/45... August 27, 2022 * 17 posts * 120 views General Tech Cruise control problem ... Read more >>
Continue reading...
ArcAngel
