Highlighted posts from Tuesday, Aug. 30, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
August 30, 2022 * 21 posts * 240 views
MatteoLC said: Yeah - it's the same wheel, except for different shading in the pockets of the spokes. (As far as I know). The 94/95 are all "natural" color - the 96/97 have dark gray painted ... Read more >>
August 29, 2022 * 7 posts * 30 views
CassieWinch3ster said: I was wondering what throttle body would be better for performance between an SR Performance 75mm and a BBK 70mm Read more >>
August 29, 2022 * 6 posts * 51 views
waynenorcross said: Replace it. Not worth the risk. In Massachusetts you can't have a tire repaired if the damage is in the sidewall. Read more >>
August 29, 2022 * 3 posts * 30 views
sanyarcosean said: I just asked you a question last week on your 245 tire video! Thanks for thw quick reply and Great to see you here! Looking forward to your guidance as I work through my CAM Build! Read more >>
August 29, 2022 * 2 posts * 17 views
samsonhusky said: On my 96 gt the headlights will come on and eventually go off. The switch is in the off position. I replaced it already thinking that could have been the trouble that wasn't it. ... Read more >>
August 29, 2022 * 13 posts * 190 views
Korn phono 52 said: New dude/going through same shit w/ 2003 gt. Only 62, ooo yea, rite,replacing everything, worked at parts store, bosses getting pissed, using my discount, car will never be rite Read more >>
August 30, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Why did the tire size change from 255/45 to 245/45... August 29, 2022 * 19 posts * 184 views General Tech Time damage question August ... Read more >>
August 29, 2022 * 11 posts * 210 views
joemomma said: Cleaned the MAF wires last year while chasing idle issues, but I can clean it again for grins. Replaced the IAC valve and did a base idle reset, still rough idle. I didn't go for ... Read more >>
August 30, 2022 * 11 posts * 291 views
chrisp427 said: So I have a turn signal issue also, all of my turn signals work except the passenger side front signal doesn't work. The rear passenger signal did blink fast until I changed the ... Read more >>
August 29, 2022 * 47 posts * 1,115 views
JDMac34 said: Hopefully I don't make this post too many more times, but I missed my New Edge yesterday! I still have it, but I took the S197 to an autocross that ended up having an open layout ... Read more >>
Continue reading...
Srchop16
