Highlighted posts from Tuesday, Aug. 23, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
August 22, 2022 * 25 posts * 142 views
cobrajeff96 said: Really any wire with +12vdc going through it should be fused whether they're HAAT or HIR. The 33 & 35 just feed the power, but it's 17 that is the switched kind of power to trigger ... Read more >>
August 22, 2022 * 26 posts * 261 views
lwarrior1016 said: Factory ford manual will always work. There is a book at Barnes and noble "how to rebuild ford 4.6/5.4" that I've read through a couple times and it seems to be really well put ... Read more >>
August 22, 2022 * 7 posts * 54 views
lwarrior1016 said: It wouldn't hurt to pull the grounds off and clean them, then reinstall. You could also try running a different power cable from the battery to the starter to make sure it's not ... Read more >>
August 22, 2022 * 3 posts * 21 views
ctroyer98 said: Purchasing my second SN95. This one is a 94 GT. Currently has a T5, looking to swap to a built AODE or Built C4. Car will be a street/strip car, mainly strip. Both transmissions ... Read more >>
August 22, 2022 * 7 posts * 118 views
joemomma said: Ordered a Motorcraft one this morning along with a new Motorcraft TFI module. I figure I'll go ahead and replace it while I've got the air filter and stuff out of the way. It looked ... Read more >>
August 23, 2022 * 4 posts * 17 views
wkualum said: New member guys. Thanks for having me. Bear with me on this...as I am having some serious regret. Backstory - I have owned a 1994 manual V6 since May of 1995. I bought this car ... Read more >>
August 22, 2022 * 1 post * 20 views
RacerX said: Has anyone tried or heard the MBRP Catback for 99-04s in person? Seems like it sounds good from the videos I have watched but I'm mostly curious about the fit and finish at that ... Read more >>
August 22, 2022 * 1 post * 15 views
Jedimeister said: Hi... new guy here. Just got a 98 GT and of course as soon as I get her, the steel brake line going from the front to the back of the car springs a leak. So, I need to replace ... Read more >>
August 23, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Parasitic draw FOUND, Generator, but why? August 22, 2022 * 26 posts * 177 views Electrical & Stereo How hard is it to rebuild a ... Read more >>
August 22, 2022 * 56 posts * 684 views
robster94gt said: Ok, I've got everything installed and running. I set the A, B, and Sub channel gains using the ohms law calculations I found on youtube - setting the multimeter to AC volts, and ... Read more >>
Continue reading...
