Highlighted posts from Wednesday, Aug. 24, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
August 23, 2022 * 31 posts * 262 views
dwcopple said: LMR is sending me a new alternator. Now let's figure out the 2nd issue. That Maxi fuse controls several things. I'll try the cluster, what else is easy to try? Read more >>
August 24, 2022 * 9 posts * 63 views
Addermk2 said: You need: Auto pedal assembly (unless youre ok with having a dead clutch pedal Jumper in the harness where the clutch switch plugs in Auto trans harness section (not optional if ... Read more >>
August 23, 2022 * 6 posts * 78 views
lwarrior1016 said: You're going to be just fine. If you wanted to keep you manual, then keep it. It should all bolt up to the 5.0, you'll just need a tune afterward. Read more >>
August 24, 2022 * 7 posts * 89 views
MyBoxersSayJoe said: Damn. It's in good hands now, though! Knowing myself and mustang owners, it's always a risk buying used. Never went nuts with my car. One car was completely OEM when I got it. ... Read more >>
August 23, 2022 * 11 posts * 146 views
cobrajeff96 said: First of all, if you're only occasionally romping it, forget about oil pump gears and the crank sprocket. Second, $900 for a K frame seems exceedingly high. Unless things've changed ... Read more >>
August 23, 2022 * 3 posts * 21 views
scca vette said: I have aquired a new problem this week. I have been working on the 96 GT and the fan has decided to start running ALL the time, even with the car off. I did a search and did not ... Read more >>
August 23, 2022 * 2 posts * 19 views
hufficon said: My grandson was gifted a 2004 Mustang convertible and a couple of boxes of parts. The problem is the fuel tank mounts on the uni-body are rusted out. There is other rust under ... Read more >>
August 23, 2022 * 1 post * 20 views
Venompower said: So based on other things going on with the car, I'd like to know what my actual oil pressure is doing. I liver about 30 min from autometer and planned on grabbing a mechanical ... Read more >>
August 24, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Cruise control problem August 22, 2022 * 25 posts * 142 views 94-04 - V6 Specific How hard is it to rebuild a 4.6 DOHC? August 22, ... Read more >>
August 23, 2022 * 40 posts * 1,000 views
Warhorse Racing said: Nice job! That was a really tough course design for a car with limited torque and 3.27 rear gears. The fast elements lead into really slow elements, which makes it hard to attack ... Read more >>
Continue reading...
Willd492
