Highlighted posts from Thursday, Aug. 25, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
August 24, 2022 * 29 posts * 193 views
ttocs said: anyone have alldata for that year? Like I said if it were 94/95 I could trace it out on my ford factory repair manual(the orang mustang bible IMO). Just curious have you looked ... Read more >>
August 24, 2022 * 9 posts * 58 views
weendoggy said: If this has the CCRM, it is in the fender well behind the splash shield. It has two wires that go into ONE wire that passes through the circuit breaker on the inner fender side ... Read more >>
August 24, 2022 * 7 posts * 49 views
Venompower said: I think the Oil Sender sensor is 1/4, and the Autometer Digital (decided I didn't wan the potential mess) has a 1/4 to an 1/8 adaptor... so I can find a brass t fitting with one ... Read more >>
August 24, 2022 * 11 posts * 87 views
ctroyer98 said: Yes I will be using a Freddy Brown manual valve body. The only shifter I have found so far is the Winters Performance one. I do have a tuned factory computer and have a competent ... Read more >>
August 24, 2022 * 8 posts * 114 views
joemomma said: Yep, my current '94 was "all stock" when I went to look at. Turns out, it had shorty headers, exhaust, shifter, a pretty wicked sound system, and gears. And had been painted (poorly). ... Read more >>
August 24, 2022 * 1 post * 11 views
Top Flight Automotive said: [image] *Expires 9/1/22. Promotional Discounts are applied to List Prices and cannot be combined with other offers. Some restrictions apply. The maximum allowable discount on each ... Read more >>
August 25, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Parasitic draw FOUND, Generator, but why? August 23, 2022 * 31 posts * 262 views Electrical & Stereo Manual to Auto Swap August ... Read more >>
August 24, 2022 * 16 posts * 163 views
Fast Lane said: Do a compression test and see if you have shot rings. Read more >>
August 25, 2022 * 3 posts * 110 views
OpalFrostGT said: Heat impacts pressure. Your problem is NOT pressure, pressure is a symptom of the actual cause! Determine what is getting too hot A. Is the Mishimoto radiator undersized? B. Are ... Read more >>
Continue reading...
RevJon
