Highlighted posts from Saturday, Mar. 12, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
March 11, 2022 * 9 posts * 73 views
RacerX said: They are metal. The rubber pad comes off and you just put in a bigger metal post that they sit in. Just weird to not use the spacers at all 4 corners also a bit of a pita because ... Read more >>
March 11, 2022 * 14 posts * 176 views
Pallgor said: Maybe a heat shield. They can be ball buster rattles Read more >>
March 11, 2022 * 8 posts * 88 views
07GtS197 said: Even with the tune it's still adding fuel? I had a bunch of strange issues on my 00 gt recently. I never figured it out before I sold it but I did find someone had tapped into ... Read more >>
March 11, 2022 * 3 posts * 16 views
Monday said: Crank Sensor Bolt Busted Off... and I have an idea but I don't wanna blow my car up. The fella whom helped me out designing my exhaust suggested I weld a washer on first, then ... Read more >>
March 12, 2022 * 15 posts * 171 views
Daryl said: Is the (next)replacement part I may or may not need the speedo cable itself? Or ??? I'm seeing speedometer cables online anywhere from $10 to over $100. But I don't know which ... Read more >>
March 12, 2022 * 8 posts * 116 views
itsell said: Just an update to confirm. Modern driveline said that the vent tubes offer get stuck closed after the transmission is assembled. They said to squeeze it a bunch to free it up. ... Read more >>
March 11, 2022 * 1 post * 18 views
95 Blue GT said: I have lowering springs (not sure what brand) and Upr Shark CC plates and am wondering which, if any, of the stock rubber bumpstops/rubber bushings will I reuse. Going to be adding ... Read more >>
March 12, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts 98 Cobra Family Cruiser March 11, 2022 * 6 posts * 54 views Members Rides 2 Post Lift Help March 11, 2022 * 3 posts * 25 views General ... Read more >>
March 12, 2022 * 1 post * 7 views
myk said: I've owned my '98 GT since new with ten miles on it. Throughout the years I picked up four other cars, the last of which being my '01 Mustang GT. I've always done the brake work ... Read more >>
March 11, 2022 * 7 posts * 136 views
96blak54 said: Not a bad weld job. Definitely has me beat. But hacking up an intake doesnt exactly make it better. Nothing about this work says effective for naturally aspirated, but if the new ... Read more >>
Continue reading...
RevJon
