Highlighted posts from Sunday, Mar. 13, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
March 12, 2022 * 13 posts * 45 views
Mlude00 said: Hello, been looking around cannot find the answer. Hopefully someone can help. I bought a 95 mustang gt manual with no motor trans. I'm installing a 351 carbed with T5. I'm assuming ... Read more >>
March 12, 2022 * 8 posts * 58 views
ttocs said: I had to do something similar and was worried about fire so I had my pops on the ready with an extinguisher in case of but I don't see a problem. Read more >>
March 12, 2022 * 5 posts * 46 views
lwarrior1016 said: This is definitely not a new edge problem. The brake system is designed just like the 98, all the parts would swap over. Is this a northern car? Because that surely sounds like ... Read more >>
March 12, 2022 * 5 posts * 43 views
lwarrior1016 said: I think you can keep the rubber bumper that is on some shocks, but all of the rubber at the top where the plate mounts is going to be gone. Read more >>
March 12, 2022 * 21 posts * 223 views
lwarrior1016 said: So it can be a little tricky, but if we get the pin out for your gauge cluster, you can ohm the wire from the cluster down to speed sensor connector and make sure the wire is good. ... Read more >>
IRS
March 13, 2022 * 2 posts * 13 views
Booboo said: Will a 2018 GT IRS swap into a 1997 GT? If so, how hard would it be? Read more >>
March 13, 2022 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts 2 Post Lift Help March 11, 2022 * 9 posts * 73 views General Tech Rattling engine noise on cold start March 11, 2022 * 14 posts ... Read more >>
March 13, 2022 * 1 post * 7 views
dramos1st said: hey, brothers. I come here to ask for your help. I want the design of the letters for the rear bumper in corel draw and with the right measurements for me to have a sticker made. ... Read more >>
March 13, 2022 * 43 posts * 594 views
J_lope82 said: That's what I'm thinking that I have 3.73 but I counted the teeth when I replaced the axles and I came up with 3.27. It doesn't feel like 3.27. I'm trying to figure out what I ... Read more >>
March 13, 2022 * 13 posts * 337 views
garrittpwl said: Blankenship was able to take car of me. I've already put 550 miles on it :) Read more >>
Continue reading...
FHCee
