Highlighted posts from Sunday, Jul. 03, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
July 03, 2022 * 12 posts * 73 views
cobrajeff96 said: Bushings are everything to me. Not sure of your suspension setup or mods, but I never run OEM rubber and it's been a long long time since any of my suspension was factory components. ... Read more >>
July 02, 2022 * 4 posts * 24 views
amf201091 said: I replaced my 98' Gt with front cobra r brakes/ss lines. After installing I went to bleed brakes but now I have no brake pressure. I doubled checked everything and no fluids coming ... Read more >>
July 02, 2022 * 6 posts * 47 views
Pallgor said: I'm going through 460 problems myself. Left bank speakers fade in and out. My CD player works but no sound most likely the kenwood head unit doesn't plug into it Read more >>
July 02, 2022 * 4 posts * 51 views
Bronco2Fan said: It really needs a refresh on the drive line for sure. I just want it to be reliable when I choose to use the skinny pedal. The tranny and suspension are all original parts and ... Read more >>
July 02, 2022 * 1 post * 14 views
er1kgr33n said: I have AFR 165's and a ported intake and am looking for bigger injector setup. My choke point is my MAF and injectors. Is it worth using factory computer and upgrading to a larger ... Read more >>
July 02, 2022 * 1 post * 10 views
carid said: [image] If it's time to replace the brake pads or rotors on your Ford Mustang, you should definitely check out basic and performance brake options manufactured by TRQ. Being designed ... Read more >>
July 02, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Coyote Swaped 02, coilover help.. July 01, 2022 * 10 posts * 64 views Suspension and Brakes New Mustang, unknown problems July 01, ... Read more >>
Continue reading...
RevJon
