Highlighted posts from Sunday, Jul. 24, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
July 23, 2022 * 12 posts * 34 views
sn95slobrah said: When should my fan be coming on ? My temp stays in the lower end towards cook Read more >>
July 23, 2022 * 4 posts * 22 views
dwcopple said: This one is aftermarket but looks more like the PI Ford performance than the Dorman. I need one ASAP for my car that just had the heads done. Read more >>
July 23, 2022 * 5 posts * 17 views
sn95slobrah said: I was driving today and the voltage meter pinned to the max, the Abti lock brake and battery light came on ??? Went away after in Neutral but comes on again with throttle Read more >>
Pallgor said: My syncros are taking a dump. I've heard there's an additive that I can put in to buy me some time before I make my decision on what I'm going to with the trans. Is that true? Read more >>
July 23, 2022 * 3 posts * 15 views
Daryl said: One pair of very decent door cups. I'm referring to the black plastic piece that holds the switches. These are off my '95 Mustang Cobra coupe. $20 + shipping [image] I'm a terrible ... Read more >>
July 23, 2022 * 4 posts * 58 views
lwarrior1016 said: Woah! You looked at the negative terminal and it melted?!? Where'd you get the superpower? Any way you could post up a picture of your melted terminal? A lot of times they melt ... Read more >>
July 23, 2022 * 1 post * 13 views
Daryl said: Is this normal?. Never noticed it before, but seems like a pretty radical stagger. [image] Pretty much a 45 degree angle accelerator pedal to clutch pedal. Read more >>
July 23, 2022 * 1 post * 10 views
Daryl said: I need the plastic anchor (black in color?) that married the drivers side door lock rod to the metal "hook" on top of the door actuator. For my '95 Mustang Cobra coupe. Thanks! ... Read more >>
July 24, 2022 * 1 post * 10 views
MichaelS0613 said: Does anyone know where the Vacuum controlled HVAC motors are located in a 98 GT? I'm having an issue where when I turn the HVAC system on, the air comes comes out of the front ... Read more >>
July 23, 2022 * 1 post * 8 views
SN95Newsletter said: Click here to view on the web Highlighted posts Looking for...stock shift lever and handle.. July 22, 2022 * 13 posts * 78 views 96-04 - 2V Specific Have questions about 94 5.0 ... Read more >>
Continue reading...
RevJon
