Highlighted posts from Sunday, Sep. 18, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
September 17, 2022 * 11 posts * 51 views
dwcopple said: What would cause that? Here's my filler hose. What is the loose bracket around the hose??? Is that the wrong type of hose? Read more >>
September 17, 2022 * 13 posts * 139 views
tinnocker said: Most 302/5.0 headers aren't made to give enough clearance for plug removal on the p heads without loosening the headers some as you loosen the plug to remove the plug. If the header ... Read more >>
September 17, 2022 * 44 posts * 367 views
94StewFord said: people just don't believe me but just for shits and giggles, go and either pull/inspect or drag a volt meter down them and see if there is isn't some random fuse that has NOTHING ... Read more >>
September 17, 2022 * 11 posts * 132 views
07GtS197 said: I'm probably in the minority here but I wouldn't pay that much for a throttle body. I've used two no brand 75mm throttle bodies for years without issues. I'd look high and low ... Read more >>
September 18, 2022 * 4 posts * 54 views
TrickVert said: This is the first I've heard of using Taurus calipers on the rear. The Cobra used the stock GT calipers on a larger rotor. What's the Taurus mod involve? EDIT: Never mind - [link] Read more >>
September 18, 2022 * 5 posts * 47 views
Venompower said: Completed, and working correctly! IATS were in the mid 80's even after a decent drive a couple pulls... glad this is measuring accurately. Read more >>
September 17, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Heads question September 16, 2022 * 12 posts * 88 views 94-95 5.0 - Specific Another Brake Question... September 16, 2022 * 2 posts ... Read more >>
September 17, 2022 * 9 posts * 130 views
Clutch Cargo said: Good suggestion b1pig. I did get the replacement. Even though the motor is different it looks like I can swap them. The one that came with it is not working and the seller said ... Read more >>
Continue reading...
RevJon
Staff online
