Highlighted posts from Thursday, Feb. 24, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
February 23, 2022 * 18 posts * 127 views
badass98svt said: Yeah that car took a hard hit. That's what I was getting at earlier. I'd like to see some more pics of the damage. Can we see the frame rails? Is there another part creased in ... Read more >>
February 24, 2022 * 7 posts * 48 views
dcm0123 said: Had a similar problem on my 94. Not sure why but when I accelerated the belt would tend to ride off the side of the idler "below" the alternator. It would be properly centered ... Read more >>
February 23, 2022 * 17 posts * 141 views
96blak54 said: Their is a reason why he does not attend forums anymore and narrows himself to fb. And i believe you have witnessed that exact reason. Now that his god complex can control the ... Read more >>
February 23, 2022 * 8 posts * 73 views
That Mustang Guy said: A pre-bent kit 4 vs 6 point Isn't that much different in price. The biggest difference would be the labor cost. If you are just doing this at an entry-level deal, Just do the 4 ... Read more >>
February 23, 2022 * 27 posts * 305 views
RAU03MACH said: Another thing I notice is some of these came with original windage tray that bolted to the cap bolts and is tucked inside oil pan This is one that I will have to add and dose not ... Read more >>
February 23, 2022 * 5 posts * 37 views
cryptospook said: Tech sheets are in there. It's not very easy to navigate through all the documents though... Read more >>
February 23, 2022 * 38 posts * 258 views
ttocs said: putting a layer of vasaline on the seal and then closing it and then opening it up to inspect could tell you where it is in contact and where it isn't. I would still bet on the ... Read more >>
February 23, 2022 * 9 posts * 110 views
Frank.JD.Perez said: i also still run the factory front sway. not that i dont want to upgrade, but its good enough for my set up currently Read more >>
February 23, 2022 * 3 posts * 41 views
Pedrothecobra said: its a 2 owner, clean car no accidents. it is a svt cobra base. last reported event was 12/03/21 and last reported mileage was 7,351 Read more >>
February 23, 2022 * 5 posts * 47 views
joe65 said: on my last fox notch i used a set of reps. i had 3 reps and 1 ford wheel. i was hoping id eventually end up with all 4 ford wheels. lol. didn't happen. [image] Read more >>
Continue reading...
RevJon
