Highlighted posts from Thursday, Sep. 01, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
August 31, 2022 * 18 posts * 136 views
Notthenow said: I have thought that to work properly as"cold air" supply they need to be insulated as they go right over an exhaust manifold or headers. I would think they flow better unless the ... Read more >>
August 31, 2022 * 11 posts * 53 views
Daryl said: Owner's manual says 87 octane. Same for a 347 stroker?? Read more >>
August 31, 2022 * 8 posts * 57 views
badass98svt said: Yeah Mach 1, Bullitt, or 99/01, 03/04 Cobra seats. The Bullitt would probably be the most subdued looking if that's what you are after. Keep in mind 99-04 seats are charcoal, not ... Read more >>
August 31, 2022 * 2 posts * 22 views
Daryl said: I have the following for sale: Four Nitto Drag Radials... 304/45x17's. One set mounted on SVE black 5-spoke; the other set on silver FR500's. All four are essentially brand new ... Read more >>
August 31, 2022 * 104 posts * 633 views
ttocs said: there are a couple of things to remember here. First I don't know a lot of people that really dig into the cruise control myself, it is only the 2nd time I have go into it and ... Read more >>
September 01, 2022 * 8 posts * 88 views
98GTAZ said: SOLVED! Amperage draw as in range and I did go ahead and clean the ground connection. It turns out, however, that it was a bad ignition switch. it had poor continuity in the start ... Read more >>
August 31, 2022 * 1 post * 13 views
badass98svt said: Selling off this spare 94/95 GT Speedo cluster that I have laying around. Has 101k on it. Someone installed white face gauges, and there is a red "Mustang" sticker on the tach. ... Read more >>
September 01, 2022 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts Throttle Body August 30, 2022 * 9 posts * 70 views 94-95 5.0 - Specific Cruise control problem August 30, 2022 * 93 posts * 586 ... Read more >>
August 31, 2022 * 58 posts * 765 views
robster94gt said: Hey alright so it's a convertible, and I ended up putting components front and rear. Front: [link] Rear: [link] Sub: [link] Amp: [link] Head Unit: [link] Read more >>
September 01, 2022 * 13 posts * 312 views
ttocs said: I have 94/95 and I am sure they are the same but different... The hazard switch is the last thing that all the wiring goes through before it goes back to the lights. In my case ... Read more >>
Continue reading...
RevJon
