Highlighted posts from Tuesday, Feb. 15, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
February 14, 2022 * 30 posts * 303 views
badass98svt said: I'm a turbo guy here. I run a 67mm If you're not that mechanical, I'd just go with a SC. Not to mention that 76 is WAY too big for what you are most likely looking for. Read more >>
February 15, 2022 * 12 posts * 33 views
Snorky said: Greetings and salutations. This is a new project i have started, it is a change from my green turbo 2v which i mostly have documented on moddedmustangs. The goal of this project ... Read more >>
February 14, 2022 * 18 posts * 128 views
J_lope82 said: When I looked there were only two sets of arp wheel studs available. 2.5" and 3". Read more >>
February 14, 2022 * 9 posts * 63 views
badass98svt said: That's not your OEM badge though. That badge is from a 99. The one MP linked is the same one that is on your trunk now Your 95 should have a simple SVT badge, no "Cobra" underneath ... Read more >>
February 14, 2022 * 37 posts * 298 views
ttocs said: its a 4.5mm if I remember correctly and I think there is enough space for it. I got one of the tools made for it and it ended up locked onto the rod and would not come off.... Read more >>
February 15, 2022 * 1 post * 11 views
SN95Newsletter said: Click here to view on the web Highlighted posts 3" arp wheel studs installation February 13, 2022 * 17 posts * 92 views Drivetrain Turbo or Supercharger? February 13, 2022 * 22 ... Read more >>
February 15, 2022 * 1 post * 10 views
Daryl said: Gave the car a pretty concentrated and deliberate sharp stream water wash, including along door and trunk seams. Opened the trunk over usual to wipe dry the channel and tops of ... Read more >>
February 15, 2022 * 1 post * 8 views
Daryl said: I YouTubed an engine cleaning video/tutorial where the guy used a spray cleaner/degreaser in a purple spray bottle. Anyone recall what that product was? Also used something to ... Read more >>
February 14, 2022 * 3 posts * 67 views
badass98svt said: I'd like to find a black air bag as well Read more >>
February 15, 2022 * 11 posts * 129 views
Flade said: If you are using the stock head unit, it does not have line out connection as expected by most aftermarket amps. The Ford Amps input full signal sound and further amplify it. You ... Read more >>
Continue reading...
RevJon
