Highlighted posts from Tuesday, Oct. 25, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
October 24, 2022 * 27 posts * 166 views
Snorky said: I have used those ptfe dry lubes before, thats a good idea. Silicone is also another great suggestion. I'll probably redo the seals along the top, the pass. Quarter glass seems ... Read more >>
October 24, 2022 * 14 posts * 75 views
96blak54 said: Ill check at work, but im thinking ford never made a npi with aluminum crossover....ive been wrong before. The company i work for has made and still makes all the plastic ford ... Read more >>
October 24, 2022 * 11 posts * 53 views
ttocs said: Yea it is a wreck If you look at the one pic you can see two black 8 pin harnesses that are plugged in together. That harness goes from the amp at the bottom of the dash(which ... Read more >>
October 24, 2022 * 8 posts * 100 views
LEGALLYFAST said: If you are tight on budget, just run it until you break it. The trans will likely break under powershifting. If you like the T-5, you could look into the Astro A-5 as another option. Read more >>
October 24, 2022 * 3 posts * 20 views
PinkieT said: I'm putting my two convertibles in the storage garage soon for the winter. I have usually stored them with the top up, windows partly down, and a breathable cover over them. It ... Read more >>
October 25, 2022 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts Convertible top and quarter window seals October 23, 2022 * 23 posts * 125 views Exterior and Interior Interior lights not working ... Read more >>
October 24, 2022 * 49 posts * 497 views
RAU03MACH said: can you take a air hose and blow through the lines to the tank it Could be stopped up blocked off i had a nest of bugs in mine Read more >>
October 24, 2022 * 33 posts * 1,143 views
jfisher said: I really hope so. The PS LT's and X pipe were super quiet. Too quiet really. I am hoping it is much louder with this setup. Read more >>
Continue reading...
Superman3872
