Highlighted posts from Wednesday, Oct. 26, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
October 25, 2022 * 20 posts * 132 views
98GTAZ said: Here's some other data from my latest readings: B1 O2 S1 Voltage: 0.081-0.85 B2 O2 S1 Voltage: 0.065-0.81 MAF Air Flow Rate: 0.7lb/min MAF (Gallons per second): 5.72 MAF (volts): ... Read more >>
October 25, 2022 * 15 posts * 86 views
Eros Akira said: Solution: take your time and check carefully every fuse first. ( check the fuse boxes behind the steering wheel and the one close to the battery) If it doesn't work then: -Check ... Read more >>
October 25, 2022 * 3 posts * 25 views
ronis said: My coolant bypass hose has ripped open I replaced the hose and still overheating. My thermostat is good and coolant levels is good also. Is there anything that I could look for ... Read more >>
October 25, 2022 * 2 posts * 18 views
Dtopford said: So we finally got a chance to road trip the Cobra. First long trip for the Ol Girl since Oct 2015 or even longer. Ran from Jacksonville FL to Pigeon Forge TN and back over the ... Read more >>
October 25, 2022 * 4 posts * 45 views
NEURON said: I always store with it up to save on wrinkling, especially on older tops. Its down enough when I drive it. Read more >>
October 26, 2022 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts Convertible top and quarter window seals October 24, 2022 * 27 posts * 166 views Exterior and Interior STFT/LTFT Way Off No Codes ... Read more >>
October 26, 2022 * 114 posts * 1,236 views
SN95Prjxt98 said: I'm currently working on mine I have a cc out of a 96 with vac line on it and no space on vac tree for it. I'm going to attempt to put the electronic one in, once I get one from ... Read more >>
Continue reading...
Srchop16
