Highlighted posts from Wednesday, Oct. 05, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
October 04, 2022 * 9 posts * 122 views
96blak54 said: Probably last around 30k miles before readjusting, but if you suspect youll ever be on the rev limiter often, itll save your engine. Read more >>
October 04, 2022 * 6 posts * 25 views
WIPR said: Anyone installed a Stand Alone system on 3.8? Holley don't support or have a harness. looking for solution to remove the dash and extra wiring that will allow the car to start. Read more >>
October 04, 2022 * 7 posts * 90 views
Wmac said: When you pull the trans, check for end play in the input shaft. With any difference in tolerances between your old bearing retainer and the new one, there may be more "slop" and ... Read more >>
October 04, 2022 * 3 posts * 49 views
GTR said: Best bet is to replace the shocks and see if that cures the issue. From the pic it looks stock to me. Bad shocks can cause all sorts of problems. If shocks don't fix it I have ... Read more >>
October 04, 2022 * 1 post * 15 views
SN95Newsletter said: Click here to view on the web Highlighted posts C2 Aero heat extractor install October 02, 2022 * 11 posts * 57 views Exterior and Interior Trick Flow heads October 02, 2022 * ... Read more >>
October 04, 2022 * 1 post * 11 views
SN95Newsletter said: Click here to view on the web Highlighted posts New project and 2 questions October 03, 2022 * 9 posts * 51 views 96-04 - 4V Specific C2 Aero heat extractor install October 03, ... Read more >>
October 04, 2022 * 9 posts * 198 views
94StewFord said: Motor seems to be OK, will go down about an inch and go up an inch before it stops and makes the machine gun sound. Rockauto looks like they have all the gears, rollers, etc. How ... Read more >>
October 04, 2022 * 11 posts * 725 views
silver98 said: I am interested in the black set, please lmk if they are available. Read more >>
October 05, 2022 * 9 posts * 281 views
white95 said: Exactly! I'm hindsight, I messed when I spec'd mine and should've gotten the front wheels in the same offset/width as the rear pair. [image] On top of that, the matte finish on ... Read more >>
Continue reading...
