Highlighted posts from Tuesday, Jun. 28, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
June 27, 2022 * 19 posts * 231 views
Frank.JD.Perez said: as for the whole quad shock shit, engineers dont always know what theyre talking about and theres plenty of proof out there about that. run them or dont. your car. everyone has ... Read more >>
June 27, 2022 * 5 posts * 35 views
joemomma said: Anyone make a spring lower than Eibach Sportlines? While I'm happy with the current stance, it wouldn't hurt my feelings if it was just a touch lower. Maybe I just need to remove ... Read more >>
June 27, 2022 * 9 posts * 122 views
ttocs said: I had 6.5" bazooka's in my old ranger 25 years ago and loved them. IT was all that could fit behind the seat of my regular cab ranger. Eventually I started wanting more and swapped ... Read more >>
June 27, 2022 * 19 posts * 327 views
PinkieT said: Yep, $750 plus parts to do a rear is reasonable. I had a cracked differential carrier and my wife had broken limited slip gears, and so we had to do both in the last year. Read more >>
June 28, 2022 * 1 post * 12 views
ttocs said: I thought this was pretty cool. I saw the vid the first time and wondered how it stuck to the road so well. [link] Read more >>
June 28, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Widest Tire June 27, 2022 * 15 posts * 128 views Exterior and Interior How reattach insulation underside of hood? June 26, 2022 ... Read more >>
June 27, 2022 * 12 posts * 230 views
cobrajeff96 said: ...However I've seen Coyote owners have a single cracked 'tooth' in an OPG and the car still runs and pushes oil just fine. Often times the owner didn't even know they were broken ... Read more >>
June 27, 2022 * 16 posts * 570 views
badass98svt said: If you say so. [image] I was asking about the bumper and hood because I assume you would have more bites if they were on the car. Is the original bumper still available? The OEM ... Read more >>
June 28, 2022 * 74 posts * 1,991 views
chrisp427 said: Found out I needed to connect a brown wire to a white wire that runs to the ignition box. Car fired right up. Now I have a cooling issue, go figure! Always something. Read more >>
Continue reading...
RevJon
