Highlighted posts from Wednesday, Jun. 29, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
June 28, 2022 * 5 posts * 49 views
ttocs said: yes they are dependent on the sides being SUPER close to the ground and when there is too much space and suction is lost it goes from amazing traction to NONE. I didn't know about ... Read more >>
June 28, 2022 * 7 posts * 115 views
Daryl said: I'm running the MM "Sport" series Adjustable LCA's. Super easy to raise/lower ride height... just turn the Allan nut! On a flat surface, I just measured the gap between top of ... Read more >>
June 28, 2022 * 2 posts * 18 views
Daryl said: Off my '95 Mustang Cobra. Approximately 1,000 GENTLE miles on them. Includes everything you see here. I'm located in SoCal. Prefer local but will ship (probably costly due to weight/size ... Read more >>
June 28, 2022 * 10 posts * 189 views
Tturaider said: Just installed new speakers in my 94 vert. Bypassed the Mach system with the additional merry harness that plugs into the connector I removed from the amp under the dash. You just ... Read more >>
June 28, 2022 * 1 post * 25 views
delling3 said: I purchased these calipers with the plan to upgrade the stock front brakes on my '96 GT. I subsequently sold the car, and will not be using them. Add rotors and pads and you have ... Read more >>
June 29, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Widest Tire June 27, 2022 * 19 posts * 231 views Exterior and Interior Lower than Sportlines? June 27, 2022 * 5 posts * 35 views ... Read more >>
June 28, 2022 * 21 posts * 672 views
Makoto said: I do. it comes too far down. omits the clean lines of the GT bumper. Read more >>
June 29, 2022 * 7 posts * 115 views
That Mustang Guy said: Yes CRC makes an actual Mass Air Flow Sensor Cleaner and the can says just that on it. Personally, I have used brake clean and electronics cleaner before with no problems. To be ... Read more >>
June 28, 2022 * 76 posts * 2,062 views
ttocs said: make sure the fan is going on in both low/high speed. Read more >>
June 28, 2022 * 7 posts * 514 views
That Mustang Guy said: If you are talking about setting up a 2-step via SCT/HPTuners and others. I have tuned many 96 and up Mustangs, But only certain PCMs/ECUs will allow the 2-step to work properly. ... Read more >>
Continue reading...
jonathanlenry
