Highlighted posts from Thursday, Jun. 30, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
June 29, 2022 * 10 posts * 150 views
J_lope82 said: If you all had to choose between cutting the springs or removing isolators which one would you all do and why? I'm looking for slightly more drop as well. Read more >>
June 29, 2022 * 3 posts * 16 views
cobrajeff96 said: Motor has spark, so that must mean the ECU correctly senses the crank trigger pulses. I've definitely got fuel provided from tank, no question. Air is good, no restrictions, and ... Read more >>
June 29, 2022 * 2 posts * 37 views
TrickVert said: Curious: If there's no Cobra logo, that likely means they're aftermarket equivalents, correct? You may want to list the manufacturer. GLWS. Read more >>
June 30, 2022 * 1 post * 3 views
SN95Newsletter said: Click here to view on the web Highlighted posts goodwood record June 28, 2022 * 5 posts * 49 views General Multimedia Lower than Sportlines? June 28, 2022 * 7 posts * 115 views ... Read more >>
June 29, 2022 * 8 posts * 136 views
RAU03MACH said: i dont use any brake cleaners on electronics or sensors it will eat plastic i will carb cleaners throttle body cleaner electrical contact cleaner mass air flow cleaner Read more >>
June 29, 2022 * 24 posts * 484 views
JDMac34 said: This has been a big week for CAM class in my region... My buddy with the 1996 Camaro that I typically battle with sold his car and bought his dream car, a C6 Corvette Z06. It is ... Read more >>
Continue reading...
RevJon
