Highlighted posts from Wednesday, May. 18, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
May 17, 2022 * 10 posts * 68 views
Adfalenski said: The multifunction (turn signal) switch on the steering column will cause all kind of crazy indications if the plugs are not in completely. There is one connector on top of the ... Read more >>
May 17, 2022 * 26 posts * 372 views
Warhorse Racing said: Thanks for checking out my videos! I have not used the PM3L on my cars. My SRA car uses a very simple rear suspension setup, but it's very capable: Steeda adjustable rear sway ... Read more >>
May 17, 2022 * 6 posts * 74 views
Wood's 5.0 said: Wow! I haven't seen a real set of those in prolly 20 years. Good luck finding a set. I supposed you've already looked in the usual places. I can only imagine what a NOS set will ... Read more >>
May 17, 2022 * 5 posts * 42 views
Taydan said: Hey all- I recently purchased my first Ford Mustang on Sunday the 15th. It is a 2001 V6. Going into the purchase I noticed the locks were not working, and was able to negotiate ... Read more >>
May 17, 2022 * 11 posts * 151 views
ttocs said: most alarms will kill the starter when they activate so it would not even crank if that were the case. Read more >>
May 17, 2022 * 10 posts * 137 views
NEURON said: Can't you drive it out using a socket any more, used to be pretty easy. Read more >>
May 17, 2022 * 6 posts * 90 views
ProMach1 said: Update for anyone interested... replaced plugs with TR6 iridium's and cleared the codes and have been all good ever since. Read more >>
May 17, 2022 * 4 posts * 119 views
Wood's 5.0 said: Hello and welcome to the forum. Nothing like that Flowmaster sound, huh?!:cool:. Right on! Stock heads, stock cam? Sorry, brother, but you are not going to see much difference ... Read more >>
May 17, 2022 * 1 post * 11 views
Potzie said: Is there a fix for a cruse control that doesnt hold constant speed. Since replacement parts are no longer made , and I dont want to try another used one from junk yard Read more >>
May 17, 2022 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts Idling issues and in need of some help! May 16, 2022 * 22 posts * 197 views 94-95 5.0 - Specific Budget Suspension Upgrade? - (Team ... Read more >>
Continue reading...
jonathanlenry
