Horsepower, Torque and the Space Between
mcglsr2
Orlando
So I've been thinking about this for a while. I decided to make a thread about it, but wasn't really sure how to proceed. I'm still not really sure. But I figured I might as well get to it anyway.
Warning! This thread will have words. A lot of them. If you don't like reading, I'm sorry. If you do like reading, I hope you find the following was worth your time.
Torque and that Horsepower Thing
This may be info you already know. If so, sorry for rehashing it. I've been planning my HCI for a little while now, and I find myself sort of at a dilemma, particularly with the cam and to a lesser extent the intake. I have choices. I can get a cam that makes more low-end torque, or one that makes more high-end horsepower, but not one that does both (Note: sort of. There are cams that will shift the peak horpsepower and peak torque numbers up in the RPMs, this is sort of like having higher HP *and* higher TQ - but of course there will be much less low-end torque).
And now, the Question: so which do I want? Low-end TQ? High-end HP?
There are a number of old adages you may have seen, here's a couple:
Horsepower sells cars, torque wins races
Horsepower gets you down the straights, torque gets you out of the corners
There's an obvious trend here. If you search in the internet, you don't have to go too far to find a debate on TQ vs HP, which is more preferable. I myself have this debate...with myself. I have reached several conclusions, and also created a mathematical model of the situation. This model is by no means exact, as there are just too many variables in play and to accurately account for every single one of them is essentially impossible for me to do. So I do the best I can, and estimate as best as I can. For my model, while not exact, I think is still fairly accurate.
I created this model to compare "cars" with different engine configurations - one with low-end TQ vs one with high-end HP, which is actually faster, etc. Otherwise, everything I read or thought would be simply speculation. I wanted to know, with some degree of reasonableness, what the time from, say, 0-100 mph for that low-end TQ car would be compared to that of the high-end HP car. All in an effort to better understand and be able to choose the cam for my particular goals. I learned a couple things along the way.
The following is based upon my findings and my opinion. I don't profess to know the "real" answer. Just what I think. You are welcome to disagree, poke holes in my theory, tell me I'm wrong, etc. Because I might be. So, with that said, what I found can be summed up with:
Power (HP) is ultimately the thing that matters. But that is not to say torque (TQ) doesn't matter, as HP is a calculation of TQ. Power, however, is what gets you out of corners, down the track and wins races. However, they can be manipulated such that they are equivalent.
Okay, So What Does This Mean
Let's start by defining the two terms real quick: Torque is a (rotational) force applied to something. It's how "hard" something is being turned. Think of it as Work being done. Horsepower has an esoteric definition that involves literal horses. For this discussion, we don't care about that. Go look up the real definition if you are interested. What it means here, essentially, is how *quickly* that Work is being accomplished.
It can be summed up thus: Torque is the amount of Work being done, Horsepower is the rate at which that Work is accomplished. Carrying a box of books up a flight of stairs = Work. You can either walk up the stairs, or run up the stairs = Horsepower. Running up the stairs accomplishes the same amount of Work in less time. Thus, running up the stairs is "faster."
But you said they could be equivalent? Yes. Two people, three boxes of books. Two weigh 20 lbs. The third weighs 40 lbs. Person A with the 40 lbs box, walks up the stairs. Person B, with the two 20lbs boxes, runs up the stairs and deposits the first box, comes back down, grabs the second box and goes back up such that Person A and Person B arrive at the same time. While Person B was "faster" - they accomplished the same amount of work. So all things being equal other than what I described, they result in essentially the same outcome. Neither is "faster" - they are equal.
Well That's Cute, But What About My Car
The thing is, most of already have a car to start with, and not an unlimited budget for R&D to create our own transmissions, engines, etc. So we are sort of stuck with whatever the car designers/engineers have set for us. Typically this means enhancing what is already there. And it doesn't matter if it's a Mustang with some low-end grunt or a Honda S2000 AP1 with revline literally at the moon. Here's an exercise: which do you think is "faster:"
  • a relatively stock 95 Mustang GT with about 185 RWHP and 244 ft-lbs TQ
  • a relatively stock 02 Honda S2000 AP1 with about 190 RWHP and 136 ft-lbs TQ
Think about it for a second....... The answer is the S2000. Did you guess correctly? In 0-100 MPH, the Mustang will get there in about 17.6 seconds. The S2000 will arrive in about 14.7 seconds. There's a lot more going on here, of course. Such as the weights of the cars (~3400 Mustang vs ~2800 S2000), the coefficient of drag, frontal area, and of course, the transmissions (more on this in a bit).
The point here is the higher HP car with "nothing" for torque will actually power out of the corners faster than the torquey Mustang.
But how can this be???????
The Crux of the Matter: The Transmission
It's all about the transmission. Horsepower is simply the measure of torque produced at a given RPM. But to make use of that torque, transmissions are employed. And the gearing is Everything. Literally. The reason the S2000 can power out of the corners better than the Mustang is because of the gearing. The gearing for the S2000 allows it to make the absolute most of it's torque, despite that there's not much of it. Were it not for the gears, then the story perhaps might be different.
The gears allow the driver to make maximum use of the power available.
If all things being equal, and two cars make equivalent HP - then go for the one that makes the most TQ. If you have two cars, 1 makes high TQ but lower HP, and another makes high HP, but low TQ, you probably want to head towards the one that makes more HP.
This is a very general statement. It really depends on the application of the car. But, in general, more HP (as opposed to more TQ) is the most desirable.
A Tale of Two Cars
The Honda S2000 is actually a really interesting comparison, as the AP1 variant (which is high-reving, lower torque) can be compared to the AP2 variant (not quite as high-reving, more torque). Two slightly different engines in almost the same exact platform. But which is more desirable from a performance perspective? Which do you think.....?
Well, it turns out, the AP2 is actually a tad faster. 0-100 MPH for AP1 is ~15.2 seconds, the AP2 is ~11.9 seconds. Granted, I've based these numbers on stock dyno plots, so there is of course space for errors. So perhaps the gap is a bit closer. But, given that the two cars make the same HP, the one with more TQ is "faster."
But, keep in mind, from our previous comparison of the 95 Mustang vs the "slower" S2000 AP1 - the AP1 was still quicker than the Mustang. It has more HP.
And this all kind of makes sense, right? After all, HP is a measure of how much Work the car engine can accomplish. A diesel can do a LOT of Work. But not very quickly.
In Conclusion
So to bring it back around, for me, I am looking for a cam that makes more HP, as opposed to more low-end torque.
Lastly, I will leave you with this to think about: F1 cars. F1 has, for all intents-and-purposes, unlimited budget. And those cars are fast. Fast fast fast. How do they fall out with regard to HP or TQ? Well, for HP, they are around 750 - 830 HP. And Torque? Around 177 ft-lbs. 177!!! That's less than my Mustang. Based on those old adages, am I to think my Mustang with more torque will be out of the corners faster than an F1 car? Yah, I don't think so...
So to wrap up:
  • If two cars have equal horsepower, the one with more torque will be "faster"
  • If two cars have equal torque, the one with more horsepower will be "faster"
  • If two cars have unequal torque/unequal horsepower (such that one has more torque, the other has more horsepower, and they are roughly equivalent cars), the one with more horsepower will be "faster"
  • This all assumes that the cars have equivalent weight and shape - if the cars are vastly different, then the weight, coefficient of drag, frontal area, rolling resistance has a large impact on whether one car or the other is faster.
  • This also assumes that the gearing is setup correctly to make use the HP/TQ.
Bonus, For Fun
Something that is asked a lot is what effect with a rear diff gear change have on the performance of my car. I ran this change on my car through my mathematical model. The results are interesting.
So, my car, with 3.55 gears, currently has a 0-100 MPH of ~17.6 seconds, a 0-60 MPH of ~6.7 seconds, and a top speed of around 122 MPH. If I were to swap in 4.10's, I would get 0-100 MPH in ~16.3 seconds, 0-60 MPH in ~6.4 seconds, and a top speed of around 112 MPH. So, certainly there's an improvement. But not a tremendous one. And I lose top speed. So the 4.10's make the butt dyno feel like it's faster, and it *is* a little faster, but in every day driving you probably won't notice. If you are drag racing, then every little bit helps.
g36 monkey
Orlando, Fl
I think the biggest thing you mentioned here is the gearing.
The S2k's are both geared to take full advantage of their torque.
When shifting, you should aim to drop your RPMS right down to the peak torque, and keep pulling until the power levels off, then shift again.
For example, say the AP1 revs to 12k RPM (I think it is close to that, I am too lazy to look), and it makes peak torque at 7k. You want to shift to bring your RPMS down to 7k.
So, say you only lose 3k RPM per shift, then you shift at 10k, because going all the way out to 12k is mostly not useful, because the peak torque is what pulls you through the power band and this is where you will find most of your acceleration happening.
F1 cars, as you mentioned, take full advantage of that concept. Albeit, I am having a hard time finding how many gears they have, you already know they take full advantage of the horsepower/torque ratio.
These are just my observations :)
Mustanger
Southern Oregon
But the snarling beastly sound of a V8 engine winding out & the ease of smoky burnouts outweighs anything the Honda has to offer.......for me. In my heart I wanna be Von Gitten Jr....sliding sideways through every curve ..tires smoking ,full lock countersteering & just eat up any little Honda! Have the soundwaves of my pipes shatter them to pieces...then blind them with smoke...tiresmoke! Hehe...
Pleasanton/Hayward, CA
[video=youtube;tZ8rd8Eighk]https://www.youtube.com/watch?v=tZ8rd8Eighk[/video]
PinkieT
Cleveland
I think that WHAT you want out of your car matters too! Suppose you have a cruiser and rarelygo over 4k rpm on the street. A motor with low end torque will be moreenjoyable than a peaky motor with more HP but in an RPM range you don't go into. I've got more torque under 4k rpm than a Cobra. My GT should stay with a Cobra with the same rear gears until it hits higherRPMs, I would think. I would love to see what the HP and TQ for both motors is at 2k, 3k, 4k, and 5k RPM.
1998 Mustang GT
4.6 2v 225 hp @ 4750rpm, 290 ft·lbf of torque @ 3500 rpm
1998 Cobra
4.6 4v 305 HP @ 5800 rpm, 300 ft·lbf of torque @ 4800 rpm
Am I close, or way off base?
Copied and pasted out of Word and it came out almost unreadable. Highlight the text and you can read it. Sorry!
95opal
Peak hp numbers are for dyno queens. The car with the highest average hp under the cure is always the winner.
mcglsr2
mcglsr2
Orlando
True. But it also depends on the gearing too. An engine with a flat torque band can "get away" with less number of gears. A peaky car can still be faster, if the gearing is set up to keep the revs in that peaky area. The end result is that for that section of the curve, the car does in fact make more average power under the curve.
The power under the curve is true, and the curve is defined by the engine and the gearing in the trans.
Another way to think about it - F1 cars with 800 hp and 177 ft-lbs of torque could be thought of as dyno queens. But clearly aren't :). I tend to think of those Supra's with really high HP as dyno queens. But if their gearing is setup to use the power, then they can be quite fast.
mcglsr2
mcglsr2
Orlando
I think
1998 Mustang GT
1998 Cobra
If you can point me to dyno sheets for the cars I'll run them through my model.
mcglsr2
mcglsr2
Orlando
Ive tried searching as well for the number of gears they have. I think the reason it's so hard to find is:
  • Probably a team secret so as not to give advantages to the other teams
  • I bet they change them for each race - both number of gears and ratios
95opal
First off you cant compare an f1 gearbox to a manual shifted trans. Its like comparing a coach and wagon to a Porsche. Second its not secret that f1 cars have between 4 and seven forward gears and most run 6. What the actual gearing for a particular car would depend on a number of variables.
mcglsr2
mcglsr2
Orlando
Yes, obviously they are different. I wasn't comparing the two transmissions as they are quite clearly different animals; rather I was simply pointing out that even a "peaky" engine can be utilized successfully with the appropriate gearing.
And perhaps "secret" was the wrong word to use. However, your response demonstrates what I was getting at: is it 4, 5, 7? It depends. Which is why there isn't any definitive answer. And while I don't race F1 - thus I'm not an expert - I have a hard time imagining that race teams will advertise the number of gears and ratios they use for specific tracks. It was merely an observation.
95opal
Most run 6 some will run 7 if there using an engine with a narrow powerband. My statement about the difference between f1 trannys and manual trannys was more directed at g36 as he was mentioning loss of rpms between shifts. F1 gearboxs shift within miliseconds which reduces that rpm drop to almost nill. The gearbox ratios are determined by starting with the the highest gear so that its just about at redline on the end of a straight. They will next set up the lowest gear to get them to accelerate out of the corner the fastest. They will then set up the rest of the gears so thete spaced evenly between those ywo starting points. So as you stated a lot of that is based on the track there at.
mcglsr2
mcglsr2
Orlando
Gotcha. Yah, those are quick shifting. Some DSG and sequentials are on the order of like an 8ms shift, which is just nuts.
Nighttrain
Atglen pennsylvania
..........keep in mind a diesel held the land speed record for how long? Torque rules all.....f1 cars, miatas, s2000's, their biggest benifit besides high reving is power to weight ratios, but youre already working on that.....
Just my 2 cents
Markstang73
