What's the difference between the 98 and early 99s a c lines and the rest of the 99-04 lines??
trixy&allee
When I read it my a c the ac manifold Line it connects to the compressor Was leaking on that little bleeter thing on the side I took it off and put a new o ring on But when I tightened it up it broke off I went to buy a new one no one has one Ford said that I specifically need one for a 98 and 99... Which is weird because I thought all 99s-04s were the same So I can buy this piece but it's for a 2000- 04 And the dealership says the part numbers don't match up And that it won't work... Apparently the one I need has been discontinued to know when carries it. And it's only the fits Ninety eight and early ninety nine... Has anyone run into this finding one at a junkyard seems to be impossible.... My question is, has anyone Interchange to ac partsScreenshot_20230814_171114_Chrome.jpg
T
trixy&allee
No one, anyway its mearly the shape, They will tell you that it's discontinued, but if you bend it (the 00- 04) carefully, you can get it to work... Hope this helps anyone in the future.
RAU03MACH
NEW MEXICO
Looking at a few diagram
From the manifold that mounts behind compressor
It Tees at each end on 99
So you need to find the proper fit and bends
T
trixy&allee
Yeah so uh I just put it in... All I had to do is bend it
T
trixy&allee
This seems to be such a rare thing. I don't know why it was discontinued... Kind of an asshole moved by ford.... I meant to come back and get the answer some glad you replied .
white95
Apex Junky
Admin
Prairieville, LA
Quite welcome!
Ford did some goofy shit in 98 & 99. They started using stuff on the 98 that was being rolled out on the 99 and then started to change things.
RevJon
