Jan 2011 ROTM winner! *Thorco3*
Matt94GT
Congratulations to Thorco3 for winning the first ROTM for 2011!!!
Body/Appearance:
HO Fibertrends hood (cobra r)
Custom polished antenna
BZ mirrors
Cobra black housing headlights
UPR wiper deletes
TrueForged Victory 18x9/18x10.5
Federal 255?s/Pirelli Rosso 315?s
Interior:
Ford Racing floor mats
ExplicitAuto gauge rings
Assorted Billet pieces
UPR 5.0 shift knob
Speed of Sound pillar
Raptor Shift Light
Sport-Comp II vac/boost gauge
Sport-Comp II fuel press - elect
Suspension:
H&R supersports (1/2coil from fronts due to a-arms)
03/04 cobra a-arms
Tokico (mach1) struts
MM 4-bolt cc plates
Mach1 dual piston calipers ? polished
PowerSlot rotors
SS brakelines
Engine/Exhaust:
95 cobra upper/lower intake ? upper polished
Vortech V2 s-trim - polished
BBK 70mm TB
90mm LMAF
42lb inj
255lph walbro fuel pump
ASP smog pump delete
Ford Racing 9mm plug wires
Billet wire dividers
Motorcraft cap and rotor
Autolite 24?s
Canton polished valve covers
Metco breather/adapter
K&N filter
Bassani Equal-length ceramic headers
Bassani o/r x-pipe
Bassani BX system/tailpipes
DynoTuned: 281rwhp/355rwtq
Drivetrain:
MGW shifter (black handle)
Spec stg2 clutch
Spec alum flywheel
Ford Racing alum driveshaft
Awaiting install:
FRPP 3.73?s
MM full-length sfc?s
Canton aluminum exp tank
Bullitt pedals
DDM HID fogs
you guys should see it in person, looks 10x better both under the hood with all the polishing he did as well as on the outside.
RevJon
