Multi-Function Switch Replacement
uncltrvlnmatt
Pa.
Tools needed Phillips screw driver, 8mm 1/4 drive socket w/ ratchet and extensions, T-20 torx socket, flat tip screw driver.
1) Remove 2 8mm head bolts from bottom plastic trim panel under steering wheel.
2) Remove trim piece has 3 push in clips on the top, pry carefully with flat tip screw driver to get these out.
3) Remove 2 8mm head bolts from metal support under plastic trim piece and remove support.
4) Remove 3 screws from under neath trim peice under steering wheel with phillips screw driver.
5) On Bottom trim peice there is a phillips head plastic screw turn approxamately 1/4-1/2 turn and remove lower trim peice.
6) Carefully lift top trim peice to gain access to top T-20 torx screw for multi-function switch.
*****NOTE***** TOP TRIM PEICE WILL NOT COME OUT DUE TO KEY SWITCH, USE CARE NOT TO BREAK TOP TRIM PEICE.
7) Remove 2 T-20 torx screws from multi-function switch.
8) Remove switch carefully and disconect the 2 wiring harness plugs, and remove multi-function switch.
To reinstall perform directions in reverse.
This job took me approxamately 1 hour to do.
RevJon
