"New" SVE 170/185 heads
joemomma
Anybody running the SVE heads that have been re-released? Or ran them back in the day? How did they perform (what was your combo)? Do these work on stock bottom end?
RAU03MACH
NEW MEXICO
should be ok for stock block
the cam is what will be a deal breaker depending on cam you pick up
b303 would be good with those head and spings
RAU03MACH
NEW MEXICO
i think you siad you had a cobra intake on the car now
if that is true ithose heads and a cam with that intake is good power adder
a tune to clear it up good to go
joemomma
joemomma
I've got an Explorer upper/lower sitting on a shelf. I figured I only want to do it once when I do it, so kind of just collecting parts at this point.
ElrodKTPQ_89
Crossett, AR
I've been thinking about grabbing a set to throw on the 357w shortblock I have for my red truck, just been waiting for a post like this to see some opinions on them.
tvsn95
you should take the time to look up Tim Moss online and read his suggestions on the manifold, I run Old X302 heads (2015). they work well and will spin 7k.
I am boosted and that cures a lot of problems with heads and manifolds. But I still make 740 at 6400 and 10lbs. with this setup.
9394stang
I believe I read online that the main concern with these heads is the deck thickness for say a Turbo application.
Anyone know what that is on this head ?
I went with the AFR Enforcer's on my car - and by that I mean they're sitting in the living room, waiting for me to get out in the shop one day.
A lot of these budget aluminum heads are variations of a couple different castings - I went with AFR just because they're using known good pieces inside them and felt a little better about going with "name brand" china heads.
9394stang
Like I stated above maybe on a motor application fine.
But with anything more than 12 pounds of boost I believe there could be some issues I believe it to be 500 or.less on thicness on these.
9394stang
Well if you buy heads there us different combinations you can use them for.
If you want a budget head grab them for a upgrade over stock.
joemomma
joemomma
I didn't think the Ford aluminum heads were still available?
Anyway, no boost in the plans.
Mustang5L5
I think someone in another forum asked. The response from LMR was allegedly, "Standard".
