October '10 ROTM *01Sportchic*
Matt94GT
congrats Danielle, sorry on the late thread
MOD LIST
Suspension :
UPR Tubular K-Member
UPR Tubular A-Arms
UPR Coil over Sleeves
Ground Pounder 12-200 Coil Over Springs
Steeda Caster Camber Plates
KYB Sport Shocks and Struts
UPR Double Adjustable Upper Control Arms with Hyme Joints
UPR Single Adjustable Lower Control Arms with Hyme Joints
Performance :
PBH Cold Air Intake
Bassani Off-Road X-Pipe
Magnaflow Catback
Ford Racing 3.55 Gears
UPR Blue Thunder Short Throw Shifter
UPR Battery Relocation Kit
Fuel System :
Walbro 255 In Tank Pump
UPR In Line Fuel Filter
UPR Fuel Rails
Mallory Fuel Pressure Regulator
-8 Fuel Feed Line
-6 Fuel Return Line
Interior :
Autometer Phantom Mechanical 0-35psi Boost Gauge
Autometer Phantom Electronic 0-100psi Fuel Pressure Gauge
Speed-of-Sound Gauge Pillar
UPR Satin Window Switch Kit
UPR Satin Shifter Bezel
UPR Satin E-Brake Handle
UPR Composite Shift Knob
Exterior :
Wheel Replica 03 Cobra Wheels painted Black
Saleen S281 Wing
Mustang JDM Style Headlights w/Black Housings
Under Hood :
Custom Powder Coated Intake, Timing Cover and Valve Covers
UPR Polished Radiator Cover
UPR Polished Spark Plug Covers
UPR Satin Cobra-Engraved Intake Emblem
PBH Custom Coil Pack Bracket
Waiting for Installation (Currently in Possession) :
31x12x3 Intercooler
Walbro 255 In Line Fuel Pump
Siemen 60lb Injectors
Kenne Bell Boost-A-Spark
Tial 44mm Wastegate
Teksid Aluminum Block (Bore 30 Over)
Cobra Steel Crank
Manley Rods
Garrett Large Frame Ball Bearing 74mm Turbo
PBH Custom Turbo Kit!
RevJon
