NEW EDG
NoVa
Ls swaps are boring so something a little over the top is what I need . I originally planned on doing a 4.8 LS turbo but I’ve already got this engine why not try and make it fit .
The difference being it's easy to fit a 4.8 LS everywhere and it's hard to fit the wide hips of a Coyote anywhere.
Musturd
You ain’t wrong . But there’s plenty of big blocks in these novas . I should be able to get it in with some cheap turbo manifolds . If it ends up being a nightmare I can get a LS easily my friend has a Chevy truck wrecker . I’ve gotta spare Holley system . I’m planning on doing mustang 2 suspension up front so the shock towers won’t be a issue
white95
Apex Junky
Admin
Prairieville, LA
r3dn3ck
$700 worth of gaskets and upgraded secondary timing chains. Gaskets, obvious. Chains because "Mr. Secondary Timing Chain" being in homeboy's sig was all the lesson I needed to learn. I need some timing components, valves/springs/locks/keepers/seals/guides, head freshening, block machining, pistons, fasteners and bearings. So about $2500 more to spend at minimum before I can begin assembly. I know, there's cheaper gaskets available as complete sets from Fel-Pro but I really quite like the OEM head gaskets and exhaust manifold gaskets. Now if some of y'all will attend to my pending piston question I might be able to add another post in here ;)
white95
Apex Junky
Admin
Prairieville, LA
Two new Khobra headlights, a SN95 headlight adjuster tool (after 17 years of ownership LOL) and some stuff to utilize my external microphone while recording video.
GoPro adapter to connect remote microphone
10’ audio cable for microphone
Suprasuavy
