Replace Your Odomoter Gear /w Pics
Matt94GT
I replaced my Moms during the Holiday break and took pictures to help others.
Mustanger
Southern Oregon
Now THAT is a write up!! Wow nice clear pics & the arrows make it easy!! Thanks a lot Matt I am subscribing Plus I think I will download all those pics...
uncltrvlnmatt
Pa.
Nice plagiarizing Matt. Good write up none the less. i have been needing to replace some dash light bulbs for a while. But I was told you needed to drop the steering column. Guess Not.
ThePope
When you take the cluster apart, you don't have to take off the plastic circuit board and the metal hold downs behind it?
MikeF
hey is that if you change gears or is that one in the transon 95
im having a problem tying to figuring out your question. can you be more specific. sorry.
GaryG
Mike, i believe that speedo gear is only if ur car isnt displaying what ur mph is, which in this case it isnt...u need a trans gear for ur 4.10's
Mike, I see what you are asking now, No this gear is has nothing to do with the rear end and it will not correct you sppedo whe you change gear on your rear end, the gear that needs to be changed out when swapping gears in on the transmission.
blown4point6
Anyone know if this will fix my odometer? My speedo and everything else works fine. Well the speedo is off but that is a different story.
Crone
Amazing wirte up, and just in time... thank you!!
Markstang73
