I thought replacing the stock rear brake lines with stainless steel brake lines would be pretty easy. Unfortunately, on my ‘95 Cobra, the shock is directly behind the torx bolt with a gap too narrow to get a toes bit in.
So, I guess I have to remove the lower bolt on the rear shock and swing it backwards enough to get a ratchet with a torx bit on it in there to remove the mounting plate.
What do I need to do to make the car safe once I remove the shocks lower bolt? Jack the body up? Support the axle with stands? Or ???
I’m not sure how the car and suspension will react once I break the lower bolt free.
Thanks everyone!
Daryl
Thanks everyone!
Daryl
