SN95 LED Gauge Cluster
Echo
Columbia, SC
I found a writeup somewhere showing a way to basically sand down the blue to use any color led. The HVAC had a film you could just rip out.
Echo
Columbia, SC
Went searching and still couldn't find the write-up I spoke of. Did find a few fourms of people who did sand down the back of the gauge face and it worked fine. Just remove your needles, pull off the layer with your gauge numbers on them, and take some fine grain sandpaper to the back. Don't worry about being perfect just sand over generally all the numbers. Once you're past that first layer you should be good to go. Hvac is easier, just remove the faceplate and pull out the blue film right behind the front. Good Luck!
Twista
this looks stupid on the black GT cluster.
What bulbs shold i use for BRIGHT WHITE>.. not this blue crap. I brought 10 bulbs from amazon linked a couple pages back
and even the HVAC is this ugly blue. It doesn't look white like in the 1st post.
and here is the color i want:
KillNThrill24
Cleveland Ohio
Great bumped thread Twista since I've had red LED's just chillin for a long time.
Sooooo can someone tell me what the hell the talk is about sanding down the blue? I've got red and would really like to use them..
g36 monkey
Orlando, Fl
pull out your gauge cluster, and sand down the blue, and put it back in with red LEDs. There I told you lol
KillNThrill24
Cleveland Ohio
Perfect looks like an easy job. The final result looks a lot like my Grand Am's interior.. Definitely like the red thanks man
whiplash473
Northern IL
which white bulbs did you get? there's different color outputs for white
Bub
Pistakee Highlands
[MENTION=8202]Twista[/MENTION] I think op has a white faced cobra cluster im sure that tweaks it a bit. I did this last year my pics are a few pages back
nolan62
Loganville, GA
I have a quick question. Is there any reason not to also replace the warning, high beam, and turn indicator light bulbs with LEDs? Does anyone know what the bulb number is for those? I can't find it anywhere.
whiplash473
Northern IL
They're all the same, no one replaces them with LED becuase it's a waste of money (if you buy good bulbs).
Jimzstang
I threw some cheap led bulbs into the dash and hvac ... I like the look! Cost me 9 bucks lol
Sent from my p.o.s phone
Markstang73
