Stealth Mare: from the begining
Pleasanton/Hayward, CA
hey SN95 forum members,
so ive never posted much on the forum, but would like to be on it more often so heres some pics of the Stealth Mare.
im the second owner and got her bone stock. the car had 210k miles when i got it and i bought her for $1500. its 97 gt with stock motor with plans for a teksid build to come with hopes of 320/350rwhp and similar torque numbers. i am building the car for autocross and maybe in the future it will be road raced. if the car lasts long enough to complete my vision for it the car will be fully built with a griggs gr40 system, coyote engine and a tremec 6 speed transmission.
on to the car!
installed ford racing c springs, steeda tri-ax, magnaflow mufflers and tips
dumped the exhaust, magnaflow o/r x pipe
finally got the 98 cobras and running 275s all around, pbr calipers, matte blacked the top, got a puppy
ditched the wing and put spacers on the rears
got a set of ford racing fr500s with 275s all around and changed the rocker stripe set up on the fender
finally did something about the oxidation on the rear bumper
put on my cobra bumper along with front 13" cobra brakes
just recently changed the top again to 94 bright blue (always wanted a blue mustang)
Mod List (as of now [1.27.2021] the car is modded as follows)
Exterior
OEM Cobra front bumper
Carbon Fiber SVO Side Skirts
Griggs Racing GR-40 Fiberglass Hood
Slibtek/Griggs Racing GR-40 Carbon Fiber Widebody Fenders
FJD Performance livery Ver 3.5
Sparco Front Tow Hook (Fabman and I broke the old strap…)
Cipher Auto rear blue tow straps
TWC^2/FJD Performance Carbon Fiber Saleen T1 race spoiler
FJD Performance Headlight Intake Duct
Modified OEM rear bumper
Aerocatch Front Hood Latches
Spectre Rear Pin Style Hood Latches
Specfab Racing Hood Pin Mounting Plates
Interior
Specfab Racing Custom Roll Bar
Sparco Grid II Fixed Back Racing Seat
Cobra Suzuka Fixed Back Racing Seat
Black 3″ to 2″ RaceQuip 6 Point Harness (Driver)
Red 3″ to 2″ RaceQuip 6 Point Harness (Passenger)
Sparco Seat Base
Sparco 45* Side Mounts x 2
Team Z Motorsports Passenger Side Seat Base
White Face Gauges (speedo & hvac)
White LED Gauge lights
Sparco Ford Performance Boss 302S racing steering wheel with NRG 3.0 quick release and hub
Performance (Engine, Exhaust & Drivetrain)
Luketich Built WAP 2V
– Saleen SMS 3V WAP Block Bored 30 Over
– Boss 302 Forged Rods
– SpeedPro Flat Top Pistons
– Edelbrock Victor Jr Intake Manifold
– 6061 Aluminium plenum
– Boundary 3V/GT500 Oil Pump
– Comp Cams Stage 5 Camshaft
– American Racing Headers 1 7/8″ x 3″ longtubes
– ARP Bolts/Studs
– Clevite Racing Bearings
– Accufab 75mm Polished Throttle Body
– Port and Polished PI Heads
– Trick Flow Specialties Adjustable Crank/Cam Sprockets
– Other Supporting Bits
SpecFab Racing Custom Rear Hood Mount Kit
Mishimoto 2 Core Performance Radiator
Canton Aluminium Expansion Tank
JLT Bright Atlantic Blue Ram Air CAI
Quantum 340LPH High Flow Fuel Pump
Quantum 5/16″ High Flow Viton Fuel Check Valve
SPEC Stage 3 Racing Puck Clutch
RAM Billet Aluminium Flywheel
Ford Racing Aluminium Driveline
Stifflers Crossmember Brace
SPEC Stage 3 Clutch
Ford Performance Throwout Bearing
Ford Performance Clutch Fork
Ford Performance High Load Pilot Bearing
Custom 3″ to 2.5″ Collectors
Custom 2.5” X pipe
V-Banded Exhaust
Turner Motorsports 6oz Baffled Oil Catch Can
Maximum Motorsports Firewall Adjuster
Maximum Motorsports Aluminium Clutch Quadrant
Ford Racing 3.73 Ring and Pinion Gears
Ford Racing Boss 302 Torsen T2R Differential
Mosler 31 Spline axles
Ford Racing Differential Cover/Girdle
Ford Racing Diff Install Kit with Bearings
Steeda Short Throw Shifter
Magnaflow 4×9 Performance Mufflers
Twin 3 in tips with custom side exhaust piping
Ford 2001 Bullitt Mustang Rear 8.8 Differential
Performance (Suspension)
Fully Torqued Racing Classic Bumpsteer Kit
Modified Steeda Strut Tower Brace
Maximum Motorsports Full Length SFCs
Maximum Motorsports 4 bolt Caster Camber plates
Ford Racing lowering Rear C Springs with a coil cut
375lb Hypercoil and Maximum Motorsports front Coil-Over kit
Modified OEM K Member
Maximum Motorsports Tubular A-arms w/Delrin bushings
Maximum Motorsports Pan-Hard Bar
Maximum Motorsport Bilstein Sport struts
Maximum Motorsports Solid Motor Mounts
Maximum Motorsports Solid Steering Rack Bushings for stock K-Member
Maximum Motorsports Solid Steering Shaft
Maximum Motorsports Heavy Duty Rear Lower Control Arms (99-04)
Eibach Rear Sway Bar
Performance (Brakes & Wheels)
Wilwood Trans-Am TA/TA2 Race Spec 14″ Rotors
Wilwood Trans-Am TA/TA2 Race Spec 4 POT front calipers with BP-30 Race Pads
Wilwood 13″ Rear Brake system
Wilwood Front and Rear Stainless Steel Braided Flex Lines
WedsSport TC105X 18×10.5 ET 12 (18.1LBS)
SpecFab Custom Caliper Spacers and Bolts
Custom 9MM Wheel Spacers (Front) and Hub Rings
Yokohama/Advan A052 200TW Tire 315/30/18
ARP 3″ Front extended wheel studs
ARP 2.5” Rear extended wheel studs
Electrical
Ford Racing Speedo Re-cal tool
LED 3rd brake light moddified with a flash rate
slow rate sequential tail lights with flat black bezels
Madd Retros LED Headlight Bulbs
Caliber Customs Custom Tune
Sonoma 2017
Sonoma 2020
Frank.JD.Perez
Sounds good, what's next?
thanks guys, im focusing now mostly on suspension since i want to autocross the car, but i am planning on getting the shinoda front splitter, saleen heat extractor hood, and btifab ducktail within the end of the year; teksid block build (eventually), and hopefully down the road the frpp/svo/roush 2v supercharger if i can find one. my step dad had one on his 98 before he sold the car
DropTopPony
South Jersey
Like this brand new one I have had sitting in my garage for ten years? :)
Nice build plan you have.
Frank.JD.Perez
Big fan of the real FR500s. So hard to come by
thanks man, i saw them come up on craigslist and i jumped on them real quick
hah! no way! i saw the old thread you had where you were talking about this. i cant believe you never put it on. do you have the ford install kit too? i will definitely buy this off you when i have the funds and granted that you still have it!
DropTopPony
South Jersey
Yes I have a complete kit with install pkg. Mine is for the PI heads and I just picked up some Trickflows so I may put them together this summer....maybe :)
Frank.JD.Perez
Put on my steeda cc plates the other day. So theres about a two finger gap, my fingers at least so maybe 1inch inch and a half, between the fender and top of my tires. I want to go lower, and the fiance doesn't want that, but what would be a good coil over set up? Want to tubular the whole front (a arms and k member)
