What do you think of these spark plugs?
GTamas
Austria
I need your advice.
Do you think this is a 30-year old stock plug, or maybe it was replaced already 15-20 years ago?
And what do you make of its condition?
To me it looks very clean, maybe even too clean?
Car is stock. The gap is around 0.042 inch. Haynes manual tells me it should be 0.052 inch?
What do you think?
Daryl
SoCal
I would, at minimum, give them another shot and put them back in. Drive it and “feel/listen” how it’s firing and responding at different levels of acceleration. They do look surprisingly good for being that old, which, if they haven’t been changed in that # of years can be a sign of a very solidly-built motor! Count your blessings there!
Reminder: don’t forget to put a dab of anti-seize on the threads!
Spark plug wires still in good shape??
GTamas
GTamas
Austria
I replaced them ca. 15 years ago with Taylor 8mm ones. I need to replace one now because it touched the headers and got some small cracks on it. Rest is in good shape.
white95
Apex Junky
Admin
Prairieville, LA
Find a location that’s very dark and watch them with the engine running. If the outer insulation is degraded enough you’ll be able to see signs of arcing.
CobraRGuy
Fremont, CA
Although I would agree that these plugs indicate that the engine is running good, keep in mind that spark will fire most easily from a sharp point. Your picture shows that the end of the center electrode is somewhat rounded. If you compare this to a new plug you'll see that they have sharp edges on the electrode.
I've been using Motorcraft Iridium plugs in my engine. They're considerably more expensive, but last a long time. I've found them on sale for much lower cost, and Motorcraft offers coupons and rebates that make them even more affordable.
Just my $0.00000002 worth...
it is a whole lot easier just to grab the cable that you think is bad and run your hand down it. If it is bad, you will know....
peasant99
