Which is deeper, Chambered or straight thru?
Blueoval19
Searched and searched and can't find an intelligent answer as to which muffler type sounds deeper, not high pitch and raspy, either a chambered muffler or a straight thru muffler design? Seems like somebody has to have a scientific answer considering the general consensus between h pipe and x pipe is h pipe sounds deeper and x sounds raspy. Really want a deep rumble sound not a high pitch sound but not sure if I should start with looking at chambered or straight thru...
evilcw311
Most Evil Member!
Louisville, KY
Every setup will work be different. Mine has an x-pipe and mine sounds extremely deep with my straight thrus
B
Blueoval19
That's interesting, I thought x pipe sound raspy. I can almost identify mid pipes by there sound on YouTube. what mufflers? Do you have a video? a
evilcw311
Most Evil Member!
Louisville, KY
When I get home tonight I'll find the vid
B
Blueoval19
So in general what is deeper, straight thru or chambered muffler? And I always thought h pipe was deeper sounding and x was raspy
McCloud
Johnson City, TN
I've had chambered on h-pipe, chambered on x-pipe, straight through on both h-pipe and x-pipe. IMO the chambered/h-pipe setup gave me the deepest sound. Everything else was as loud as that, but not as deep.
Sent from my SAMSUNG-SM-G890A using Tapatalk
B
Blueoval19
thanks brother, what do you think is the deepest loudest muffler?
96blak54
Lawrenceburg Kentucky
Chambered or straight through? Good question, but my question is packed or not packed. Usually a straight through will be glasspacked and they are normally the deep rumble toned mufflers for performance. And their are "turbo" style mufflers(nothing to do with turbo, just a name). They are somewhat chambered and have quiet deep rumble that growl when rpm's are up, but buy a good brand. Something stainless or welded or youll blow them apart.
If you feel adventurous, go to the autoparts store and grab a thrush turbo or cherry bomb turbo muffler and get it installed. 2 can be had for around $50. Deep rumble is what youll get.
RevJon
