Hello guys,
I was wondering if it is possible for the pressure plate to be installed incorrectly as far as orientation goes. I had the engine out for some strut tower repairs and I decided to do the rear main seal while it was out. I am concerned that I may have re installed the pressure plate in a different orientation. I know there are dowel pins, but is it possible to misalign it even with the dowel pins?
My suspicion is because the car shakes at start up and idle, which it did not do before. I did not do any other work to the engine while it was out, and only replaced the motor mounts with OEM replacements. Unless the harmonic balancer coincidentally gave out right when I put the engine back, I'm at a loss for ideas. The car runs great otherwise.
Thanks in advance.
Thanks in advance.
