the volt gauge works as it should, and the gas gauge but all the others are not so great.
I have a different gauge panel than the stock one. I got it from Maximum95 when he parted his car out. Check out picture 1 in my July 17 post. So, I figured I would replace the AFR gauge with the water temp gauge and just leave the stock one in there doing nothing.couples? unless you got one that wires into the stock sender you can remove the one for the dash and put the new one in that spot as long as you do not mind the dash gauge showing 0. Otherwise you will need to add a spot and there are a couple of different ways depending on if you want to drill/tap.
Is it difficult or even possible to switch from the stock gauge (which I’m guessing is electric?) to a mechanical?
