2slo95fiveoh said:only switching from GT40 aluminum heads to AFR 185s they picked up 75 hp. that was the only change between the two tests
After everything is all said and done the AFRs have awesome resale value. Thumper ports GT40 heads and apparently they flow awesome afterwards but I saw some ETs and wasn't overly impressed.94GTcobra said:I know afr's are super better that gt-40's, lets say you have some gt-40p heads ported to the same flow as some afr's 165cc heads, what would be the difference.
well say you port the gt40's to flow the same as afr's. You'll still have the weight savings, and the heat dissipating capabilties of the aluminum heads. With the right intake and cam you can make 300 to the wheels with gt40s and run in the low 13's and high 12's.OnyxCobra said:After everything is all said and done the AFRs have awesome resale value. Thumper ports GT40 heads and apparently they flow awesome afterwards but I saw some ETs and wasn't overly impressed.94GTcobra said:I know afr's are super better that gt-40's, lets say you have some gt-40p heads ported to the same flow as some afr's 165cc heads, what would be the difference.
Stangbangin said:well say you port the gt40's to flow the same as afr's. You'll still have the weight savings, and the heat dissipating capabilties of the aluminum heads. With the right intake and cam you can make 300 to the wheels with gt40s and run in the low 13's and high 12's.OnyxCobra said:After everything is all said and done the AFRs have awesome resale value. Thumper ports GT40 heads and apparently they flow awesome afterwards but I saw some ETs and wasn't overly impressed.94GTcobra said:I know afr's are super better that gt-40's, lets say you have some gt-40p heads ported to the same flow as some afr's 165cc heads, what would be the difference.
