The idea of no more dry starts is what sold it for me.So your spending $342 to save $12 per oil change which should finally net you a return on your 29th oil change or in 145,000 miles if you change every 5,000 miles. What am I missing?
Those Griptec pulleys are the truth! I've been running them for years. They do a great job.New party pulley . Car doesn’t make the boost I want in the mountains . Should make 15psi now instead of 11 psi . I’ll probably just run it at the lower elevation tracks as well seasons almost over . Also ordered some 31 spline Yukon axles and new spider gears for my explorer carrier for my budget rebuild . View attachment 36715
Cool, let’s see it installed! ++This showed up today and will be going in this evening!!
Causes cancer and reproductive harm? if this thing causes reproductive harm, you might not be having sex correctly.....This showed up today and will be going in this evening!!
Wow… nice!! Super clean install. Looks like it was engineered perfecto!Not the easiest to get a pic of due to not having a lift. But install was super easy and everything is great quality. Sound is just like I wanted her to be.View attachment 36910
The splitter and side skirts definitely aren't salvageable. Cracks everywhere and that wing is just a stock 99-00 wing not saleen. The wheels seem ok from the picture but given the damage where the wheel well meets the side skirt I would definitely give them a very thorough inspection. Make sure you check the inside of each wheel because judging by the rest of the damage that took a pretty aggressive hit to the bottom side of that car.No purchase yet. Gonna hit the salvage yard and see if this Convertible is still there with all those parts on it. Saleen wheels, wing, side skirts and splitter. Been there a little while.
That's what I thought too. And if they're the real ones, I may snag them. I just figured the ground effects might be worth salvaging. Thanks for the insight, all.The only thing Saleen on that car is the wheels.
Those are definitely not real Saleen wheels.That's what I thought too. And if they're the real ones, I may snag them.
