Upgrade Your Mustang's Brakes and Save Big with PowerStop!
carid
Preferred Vendor
Cranbury, NJ
Mustang enthusiasts, rev up your engines and get ready to boost your braking like never before! We're thrilled to announce a special promotion on PowerStop brake kits exclusively at CARiD.com. From August 1st to August 15th, 2024, enjoy a cool $40 off on single axle kits or an incredible $85 off on two axle kits. It’s the perfect time to elevate your Mustang's performance with brakes that offer not just superior stopping power, but also enhanced safety and long-lasting durability.
PowerStop is well-known for its high-performance brake kits tailored for demanding drivers like you. Whether you're fine-tuning your daily driver or optimizing your track beast, PowerStop kits ensure you experience significant performance gains. This promotion is ideal for Mustang owners looking to upgrade their braking systems without the high costs usually associated with top-quality enhancements.
Don’t miss out on this opportunity to transform your Mustang with PowerStop's top-tier brake kits. Visit CARiD.com today and take advantage of these fantastic savings. Remember, prices are already reduced, so you can immediately upgrade and start enjoying a more responsive, safer driving experience. This limited-time offer is your chance to get the brakes your Mustang deserves – shop now and feel the PowerStop difference on every journey!
PowerStop® - 1-Click Z23 Evolution Drilled and Slotted Disc and Drum Brake Kit
Note: Check out "Product Options" to choose your specific model.
Key features:
  • Precision machined using a Tru-Cast™ technology
  • Rotor run out is within 0.0015 and DTV tolerance specification is within 0.005
  • All Evolution rotors are mill balanced
  • Rounded slots keep a clear contact patch between the pad and the rotor by sweeping away water, gas and dust
  • Beveled and precision drill holes help keep rotors temperatures down during extreme braking performance
  • All drilled and slotted rotors (except for hub and rotor assemblies) are silver zinc plated to helps shield and resist rust during normal operation
  • Pads, rotors and clips are designed in the precise size and shape of factory OEM parts for proper fit and operation
  • Carbon Fiber infused Evolution ceramic formula for superior braking power
  • The pad surfaces are thermal scorched for a fast break-in
  • Chamfered and slotted like the OE pad to ensure noise-free braking
  • Powder coated backing plate extends life by resisting rust and corrosion
  • Premium rubberized shims provide virtually noise-free-braking
  • Premium stainless steel hardware kit included for easy installation
  • Ceramic based lubricant specially formulated for Z23 Evolution Sport pads
  • Ceramic pad compounds wear slower and last longer than OEM equipment
  • Reduced heat buildup eliminates brake fading that occurs when brake fluid reaches boiling temperature
  • Includes rotors that are cross-drilled and slotted for more effective cooling under heavy use
  • Advanced brake pad compounds produce less dust than OEM factory brake pads
  • Brake pads and rotors offer eliminate squealing under the most extreme cold or hot temperatures
  • Shoes are arc grounded for proper fitment
  • Premium G3000 iron drums
  • Spring and hold-down kits included
  • 3-year/36,000 mile manufacturer limited warranty on the rotors and pads purchased and installed together
PowerStop® - 1-Click Street Warrior Z26 Drilled and Slotted Brake Kit with Calipers
Rotor benefits:
  • Drilled holes and Slots create an escape route for debris, dust, gases, and water
  • Slots clean and de-glaze pad surface for optimum pad coefficient of friction
  • Slots help to increase pad bite and improve air circulation
  • Drilled holes and Slots reduce stopping distances in wet weather
  • Drilled rotors improve the appearance of your wheels and provide reduced rotor weight
You can browse the full catalog of PowerStop brake parts at the link below:
Check out other active sales events and promotions here:
carid
carid
Preferred Vendor
Cranbury, NJ
We'd love to hear from you! Have you upgraded your Mustang with performance brakes before? Share your experiences or ask any questions you might have about improving your Mustang's performance with PowerStop. Your feedback helps us serve you better and also provides valuable insights to fellow Mustang enthusiasts considering this upgrade. Join the discussion below and let us know your thoughts!
