Fuel pump for 1995 5.0?
Finn
Finland
Hello.
I would need to pick your brains regarding replacing of the OEM fuel pump. As the car is almost 30 years old I woul dlike to replace the fuel pump to reduce possible problems on the road as precautionary job.
Car is stock and wil remain stock so I don't need a HiPo pump but an OEM comparable will do. Rockauto seems most convenient for me as the shipping is a breeze.
https://www.rockauto.com/en/catalog/ford,1995,mustang,5.0l+v8,1134188,fuel+&+air,fuel+pump,6256
If I look at the daily driver classified products the Carter P74151HP would contain everything I need at once - although it seems to be hi-vol pump.
Carter P74151HP
Then there is the Delphi pump & housing assembly HP10145, which is quite affordable.
Delphi HP10145
I have no idea of what Carter or Delphi quality is nowadays.
Any comments or ideas regarding stock replacement with these or something else?
Finn
Finn
Finland
Thanks for the link.
I read somewhere that 1994-95 OEM fuel pump flow rate has been 110 lph. Is that correct?
95opal
Going with a higher rate pump has no down side and will leave room for growth down the road.
Wmac
Steeltown, Ontario
I wouldn't hesitate to use a Carter fuel pump, they sure made great mechanical pumps way back in the day.
Don't forget to get a new lock-ring, just incase. And a BRASS punch.
TTSaleen
NC
As others advised, if staying mostly stock/bolt-ons, I'd go to at least a 190lph pump.
Srchop16
