here are a few pics of my junk
97turbocobra
here you go, just your run of the mill cobra ;D
[attachment deleted by admin]
97turbocobra
i dont really know, ive only had it on the street so far
here are a few int. shots
97turbocobra
it could stand to be alittle bigger just so i could get mst pics on one post, but i really have no problem putting them on 2 or 3
97turbocobra
here are some of the specs
Turbo kit (by Top End Fabrication)
gts76mm. turbo, air to water intercooler, custom water tank in the trunk,tail 40mm wastegate, vortech blowoff valve(race)
Suspention,chromemoly k-member and a-arms, custom sub frames, custom 8 point cage, chromemoly upper and lower control arms, koni struts, coilovers ,built C-4, dynamic 9" turbo convertor,b&m pro rachet,31 spline axles with 5/8" studs, sumped stock tank , barry grant king sump fuel pump, barry grant regulator,-10 feed line,-8 return line, 42lbs. injectors, pro-m mass air,all factory interior with autometer ultra lite gauge, and so on
Dan95-5.0
that sick man
never thought you can have that clean of an engine bay with a mod motor.
the one thing that would i add tho is a set of black tail light bezels. that will set it off
great car man
RevJon
