Highlighted posts from Friday, Aug. 05, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
August 04, 2022 * 18 posts * 84 views
JPuehl said: I checked on this last night and with the car not running and the clutch pedal both in and out the shifter feels the same. I'm not "double clutching" and the clutch and adjustment ... Read more >>
August 04, 2022 * 16 posts * 86 views
Venompower said: Just hadn't seen a good shot of them on an SN95, thanks. Found these about an hour and a half away for $75 [image] Read more >>
August 04, 2022 * 14 posts * 91 views
Rtfm said: The rebuilt alternators are pure crap these days. You have several options, though. Buy a new one from rock auto.com. Some new ones are about the same price as a rebuild. If your ... Read more >>
August 05, 2022 * 7 posts * 25 views
98GTAZ said: New to the forum as a registered user, but have consulted the threads a lot. I know brake pulling/caliper issues have been discussed, but I have a brake pull that does not seem ... Read more >>
August 04, 2022 * 20 posts * 211 views
Daryl said: Solved!... The stereo installer fixed my door lock rod and also installed the Ford OE replacement door cups I upgraded to from LMR. He noticed that the metal plate adjacent the ... Read more >>
August 04, 2022 * 1 post * 9 views
SN95Newsletter said: Click here to view on the web Highlighted posts Tail Pipe Question August 03, 2022 * 11 posts * 40 views Exhausts Notchy shifting August 03, 2022 * 7 posts * 30 views Drivetrain ... Read more >>
August 04, 2022 * 3 posts * 52 views
MyBoxersSayJoe said: Haven't had speedo stick or skip, but tach. The plastic gear had worn and needed to be replaced. Read more >>
August 04, 2022 * 14 posts * 198 views
Monday said: I had a problem like this, and like this, I too thought it was the bar hitting the rear end, but the sway bar actually wasn't tight enough and bounced under a load. I know it was ... Read more >>
August 04, 2022 * 25 posts * 664 views
chrisp427 said: Good information thanks. Is there a way to check the head gasket placement without removing the heads? This engine was professionally built at a engine shop I would think they ... Read more >>
Continue reading...
Sn95tre
