Highlighted posts from Friday, Aug. 20, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
August 19, 2021 * 11 posts * 81 views
evil2vgt said: 03 Gt convertible Engine: .020 teksid block Stock rebuilt pi heads MHS gen2 stage 1 blower cams 225/230 550 lift 03 cobra forged rods and pistons 9.5:1 compression Melling 10277 ... Read more >>
August 19, 2021 * 9 posts * 37 views
J_lope82 said: 96 mustang gt with full PI swap. This car came with a Pcv delete. What's is you all's experience with this delete on these cars? What are the pros and cons? I'm thinking I should ... Read more >>
August 19, 2021 * 15 posts * 188 views
Tillerman77 said: +1 on watching his video series, whether or not you plan to autoX your Mustang. I learned a lot on suspension setup from @Warhorse Racing. He also is very responsive to questions. ... Read more >>
August 19, 2021 * 11 posts * 82 views
Daryl said: Little delay at the powder coater. Seems they had a time getting the pistons out. I went by to see what's up. Watched them use the air compressor to little avail. Then used a flathead ... Read more >>
August 20, 2021 * 6 posts * 23 views
amf201091 said: Hey guys, So no coolant problems in every day use but TWICE now at a track night's event, my coolant has spewed significantly out my radiator cap. This is usually at the end of ... Read more >>
August 20, 2021 * 2 posts * 12 views
Sn95andy said: I got a 1995 mustang gt runs good but recently just randomly started turning off but it doesn't misfire before it turns off, it doesn't overheat if anyone knows why could y'all ... Read more >>
August 19, 2021 * 13 posts * 152 views
joemomma said: Side windows on my '94 weren't bad at all. I bought a heat gun from China Freight and some "plastic" razor blades from amazon. Worked like a charm. Soapy water in a spray bottle ... Read more >>
August 19, 2021 * 1 post * 9 views
RockAuto said: From August 19th through the end of August, 2021, Power Stop is offering RockAuto customers a 10% instant manufacturer rebate on their Stock Replacement Rotor & Brake Pad Kits. ... Read more >>
August 20, 2021 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts 2.6 mammoth on a 2.1 KB August 18, 2021 * 3 posts * 30 views Forced Induction & Tuning 01 GT p0190 smells like gas August 18, 2021 ... Read more >>
August 20, 2021 * 31 posts * 356 views
ttocs said: a quick search for "where to mount a slot style maf" I came up with this from svt.com "What ever you decide just know that the density of the air will increase in and right after ... Read more >>
Continue reading...
Fl510
