Highlighted posts from Friday, Mar. 04, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
March 02, 2022 * 17 posts * 104 views
Daryl said: I idle at 1000rpm. Maybe I'm just used to my truck and wife's SUV (800rpm idle), but it just bugs me. I'd like to adjust it down to 800rpm. Is this possible? Is it as simple as ... Read more >>
March 01, 2022 * 15 posts * 141 views
ttocs said: unless it is a REALLY bad leak you will rarely see or hear a leak and spraying starter fluid also can be hit or miss. Get a cigar and remove the vac line to the brake booster and ... Read more >>
March 02, 2022 * 17 posts * 206 views
That Mustang Guy said: Brisk plugs are one of the best plugs out there as well as NGK. Do not use those plugs with no ground strap, Not saying they are junk but they belong in different engines like ... Read more >>
March 01, 2022 * 27 posts * 336 views
ttocs said: sorry man, those are also not svo tips. The svo tip is probably half as wide at the front as it is in the back. Read more >>
February 28, 2022 * 7 posts * 110 views
96blak54 said: I figured someone out in sn95 land might be rebuilding a saleen or simply wanted to keep Ford parts on their Ford car. Read more >>
February 28, 2022 * 5 posts * 76 views
96blak54 said: I truly believe these intakes is what killed B head potential. But how else could Ford package an intake on a huge engine in a tiny engine compartment. Read more >>
March 02, 2022 * 19 posts * 237 views
dcm0123 said: Sorry this is not where I installed the pulley on mine. I installed it on the idler below the alternator (the tensioner). This is the one which the belt would start to ride off ... Read more >>
March 04, 2022 * 8 posts * 119 views
Daryl said: To answer your question: yes, you "can" leave them off. The wear and tear of the metal to metal is gradual and minimal or so I've read herein. But... My unsolicited $.02 ...... ... Read more >>
March 04, 2022 * 34 posts * 323 views
Gregomatic said: I did that with an AMC Jeep Eagle and it worked. Mostly. Not quite perfect, but much better than before. I also Bought a Chevy Cavalier (4 door) for $200 that had been T boned ... Read more >>
March 03, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts Will I need a tune? March 01, 2022 * 15 posts * 75 views 96-04 - 2V Specific Just picked up this beauty with 7k miles March 01, ... Read more >>
Continue reading...
RevJon
