Highlighted posts from Friday, Nov. 04, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
November 03, 2022 * 22 posts * 144 views
1994Gtmustang said: Yes, I use my fuse tester light to check every fuse under the driver side dash as well as the engine compartment it is really weird it is just that one tenant fuse that gets no ... Read more >>
November 03, 2022 * 4 posts * 31 views
TexasMade said: Not sure if it just needs to be tuned or maybe a vacuum leak but the idle is high and just falls any ideas? Read more >>
November 03, 2022 * 1 post * 17 views
apsmith49921 said: Ok so the car is a 97 cobra. Full mods in signature but fbo e85 NA. Random misfire at wot. I replaced coil packs and it got slightly better. Data log shows 0 misfire occurrences, ... Read more >>
November 04, 2022 * 2 posts * 17 views
badass98svt said: I have a brand new set of black 03/04 Cobra wheels from American Muscle. Fronts are 17x9. Rears are 17x10.5 They are literally brand new, still in the boxes. $650 shipped (+ PayPal ... Read more >>
November 03, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts fuse charts for 1994 GT 5.0 5 speed convertible November 02, 2022 * 15 posts * 75 views 94-95 5.0 - Specific wheel and tire set ... Read more >>
November 03, 2022 * 5 posts * 90 views
Jposey66 said: Update: This ended up being the exterior universal joint in the steering shaft going bad. It was completely locked up in one axis. Read more >>
November 03, 2022 * 40 posts * 459 views
dwcopple said: Pretty sure trans is toast or at least the torque converter. Slips awfully from takeoff and through 2nd gear. Like putting no power to the ground at all. Crawls from takeoff. SonnuvaB... Read more >>
November 04, 2022 * 13 posts * 438 views
apsmith49921 said: Give it a few days and if he doesn't respond I've got a used set of oem cobra brakes and brackets I'm pulling off my car Read more >>
November 03, 2022 * 38 posts * 1,222 views
jfisher said: Found some time this weekend to mess with this thing. Got the clutch and flywheel on. Went with the Mcleod Super Street Pro and a Ram Billet Alum flywheel [image] Got the trans ... Read more >>
Continue reading...
Superman3872
