Highlighted posts from Sunday, Nov. 06, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
November 05, 2022 * 17 posts * 47 views
07GtS197 said: Nevermind, maybe I'm thinking of my 87 or something having two. Anyway I'll probably try to get another one on Monday. When I got home from work this morning I popped the hood ... Read more >>
November 05, 2022 * 19 posts * 55 views
PapaSmorzy said: I was recently trying to replace the radio in my car, and found it doesn't have the wiring harness originally included in this car but an older version from probably about a 1999 ... Read more >>
November 05, 2022 * 19 posts * 108 views
apsmith49921 said: So I did not do plug wires yet. Also I did have some plug backout on the old Motorcraft but when Installed the new plugs they were torqued to spec and I still experienced the issue. ... Read more >>
November 05, 2022 * 15 posts * 92 views
Cathy9888 said: We did the coolant, and yep.. it was nasty! Filled it back up, and now it's leaking. There was a coolant leak prior to purchase, but they originally assumed it was an intake issue. ... Read more >>
November 05, 2022 * 24 posts * 204 views
1994Gtmustang said: I've traced everything down, tested every wire every circuit. Everything leads back to the PCM. I will wire up an external switch for the fan very easy, it is not my daily driver ... Read more >>
November 05, 2022 * 6 posts * 23 views
Cathy9888 said: 97 Mustang GT 4.6L 2V When we purchased the car, the previous owner said there was a coolant leak, but assumed it was the intake manifold. That has now been replaced... and there's ... Read more >>
November 05, 2022 * 4 posts * 33 views
ttocs said: pop the hood and look at the coil and there should be a small metal cap/can with a single wire going to it. It is an ignition noise reducer and for the life of me I can't seem ... Read more >>
November 06, 2022 * 3 posts * 28 views
dcm0123 said: diagram and fuses I see where it states there is a 10 amp fuse for the low speed fan but I also see in the relay schematic both low and high speed are fed by the same 60A fuse, ... Read more >>
November 05, 2022 * 6 posts * 107 views
Michael Plummer said: The advice given by 95opal is good advice but I would run a larger injector (1000cc or 1050cc) from a quality manufacturer that provides good injector data ( [link] ). Putting ... Read more >>
November 05, 2022 * 1 post * 11 views
Warhorse Racing said: I think EVERYONE should autocross their 79-04 Mustang. Getting into autocross is REALLY EASY! But many Mustang owners I meet don't know how to get started. This video covers the ... Read more >>
Continue reading...
Srchop16
