Highlighted posts from Monday, Nov. 07, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
November 06, 2022 * 27 posts * 168 views
apsmith49921 said: Tune has been on the car for several months. I've got a 93 tune and an e85 tune. I used that e85 tune all spring and summer without issue. 93 tune seems to be doing the same thing. ... Read more >>
November 06, 2022 * 18 posts * 84 views
07GtS197 said: Lol thanks. Like I said I'll look into it Monday (no pun intended) when I'm free. I'm not too worried about doing the multifunction switch. It can't be that bad. Yeah man I can't ... Read more >>
November 06, 2022 * 7 posts * 58 views
95opal said: Is the stock capacitor by the coil still hooked up? If not could be your problem. Ford part number 7L1Z-18801-A Make sure your speaker wires are not near any power wires. Read more >>
November 06, 2022 * 9 posts * 61 views
1994Gtmustang said: Everyone is absolutely correct the relays are in CCRM There's also a 60 amp fuse, and a 10 amp fuse that works in conjunction with the CCRM this is the problem, at least for my ... Read more >>
November 06, 2022 * 6 posts * 94 views
badass98svt said: [image] I'd also accept a trade for some clean 2000R wheels or ?? Read more >>
November 06, 2022 * 1 post * 13 views
abood89 said: For Sale: 03/04 Cobra Mirrors $650 shipped Payment via PayPal. Pics: [imagen] Read more >>
November 06, 2022 * 1 post * 10 views
SN95Newsletter said: Click here to view on the web Highlighted posts No Brake Lights November 05, 2022 * 17 posts * 47 views Electrical & Stereo Stock radio works fine, install an aftermarket head ... Read more >>
November 06, 2022 * 34 posts * 417 views
SnakeBit! said: Assume you tried cleaning the IAC and have checked the hose leading from it as well as the little silencer box for cracks. Read more >>
November 06, 2022 * 20 posts * 179 views
weendoggy said: Check freeplay on pedal and adjust if needed. Drive it around and see how it goes. If all's well, break it in for the 500mi +/- Another item is hoping the installer cleaned both ... Read more >>
November 06, 2022 * 38 posts * 1,222 views
jfisher said: I thought about that and found some super tight 90 degree fittings, but I just wasn't a big fan of that setup. I went ahead and ordered up a coolant crossover delete. Should clean ... Read more >>
Continue reading...
Aray176
