Highlighted posts from Thursday, Oct. 07, 2021
SN95Newsletter
Click here to view on the web
Highlighted posts
October 06, 2021 * 13 posts * 82 views
Daryl said: I went double din on mine. I also added the backup camera, and that's nice! On the plus side: looks cool; tons more options, functionality and expandability (keeping up with technology). ... Read more >>
October 06, 2021 * 23 posts * 178 views
Procharged87 said: I mean the batteries usually last 2-6 months from when it started corroding the terminal. Based on the sticker on the battery, it looks like it was sold around Jun of 2018 so, ... Read more >>
October 06, 2021 * 18 posts * 137 views
Clutch Cargo said: Thx for the offer Blueraz_5.0. If you said they were leather in saddle tan I probably woulda snapped them up in no time. Seems like shipping from Dallas to San Diego would be more ... Read more >>
October 06, 2021 * 11 posts * 117 views
Daryl said: Torn to shreds ... needs rear glass and rear deck repaired (cracked like an earthquake fissure!) :-( [image] Read more >>
October 06, 2021 * 4 posts * 27 views
Addermk2 said: If you ran the green wire from the Alt, to 12v, and it began charging... then: Inspect fuse #18 in the fuse panel under the drivers knee bolster. Check wire continuity from the ... Read more >>
October 06, 2021 * 6 posts * 74 views
Blueraz_5.0 said: Would they have those little flat top "christmas tree" (?) pins? The kind that hold on the doorsills and back interior panels and try to slice up your fingers when you yank at ... Read more >>
October 06, 2021 * 1 post * 12 views
joemomma said: This has probably been covered, but I'm looking for pics of SN with the door "bump guard" trim removed. Mine has the trim, and I'm thinking it would look "better" with that removed ... Read more >>
October 06, 2021 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Corrosion on Positive battery terminal October 05, 2021 * 15 posts * 120 views 94-95 5.0 - Specific November POTM - Project car ... Read more >>
October 06, 2021 * 8 posts * 103 views
Daryl said: Pretty sure most/all wheel websites include the weight of each wheel. So, you can whittle down your choices by weight if you choose to. Good luck and keep us posted on what you ... Read more >>
October 06, 2021 * 11 posts * 198 views
Knightstallion said: Funny, it was the new one that was damaged, and caused me to go through 3 sets of gaskets, that and the bolt i had to completely mill out of the hole and now it's back together Read more >>
Continue reading...
OnoItsMyMotherNlaw
