Highlighted posts from Tuesday, Apr. 26, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
April 25, 2022 * 13 posts * 91 views
ttocs said: well then yes if someone took the time to upgrade the CAI, but keep the stock maf then yes it would be better to swap. But from my experience most of the time they take that opportunity ... Read more >>
April 25, 2022 * 26 posts * 228 views
joemomma said: Pods delivered today. It'll be a bit before I can work on them, maybe this weekend. Read more >>
April 25, 2022 * 26 posts * 223 views
Buffalo5Spd said: Correct. Idle if you can, but you may have to bring it up to 1200-1500 max. That will keep it from stalling instantly but it'll definitely bog down. Keep in mind, if you have catalytic ... Read more >>
April 26, 2022 * 5 posts * 38 views
BrodieLarsen said: Hello my name is Brodie I'm new here and am looking for some advice to fix my overheating issues. This will be a long post since I've been fighting this issue for about a year ... Read more >>
April 25, 2022 * 49 posts * 550 views
Daryl said: warrior, Not a lot (100 mi.+\-), but so far it feels good/right. I also have the knob secured about 1/2 way up the threading, which I might adjust it down a smidge to fine tune ... Read more >>
April 26, 2022 * 1 post * 6 views
SN95Newsletter said: Click here to view on the web Highlighted posts Mach 460 Tweeter pods April 24, 2022 * 25 posts * 190 views Exterior and Interior Brake caliper bad? April 25, 2022 * 8 posts * ... Read more >>
April 25, 2022 * 75 posts * 847 views
J_lope82 said: Also I'm trying to be careful with the mods I do to the car. Meaning I don't want to over mod my car to the point it's not enjoyable to drive or I'll start having a lot of drivability ... Read more >>
April 26, 2022 * 5 posts * 101 views
Snorky said: How big is the joint 9n the steering shaft compared to the stock rag joint? And where d9es one get rear toxico D spec shocks? Read more >>
April 25, 2022 * 30 posts * 297 views
94StewFord said: I currently have a new set of Boston Acoustics Pro 6.5's and am trying to figure out whether I use them up front or keep my stock 460 up front and install them in the rear along ... Read more >>
Continue reading...
RevJon
