Highlighted posts from Wednesday, Mar. 23, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
March 22, 2022 * 75 posts * 661 views
Booboo said: I don't remember off the top of my head, but the weight is closer than that. If you add an aluminum intake, etc. you can take more weight off. This is not a radical 460. The 545ci ... Read more >>
March 23, 2022 * 15 posts * 156 views
Gregomatic said: So the ring and pinion are the only gears that change size, the spider gears always stay the same size, correct? USA STANDARD GEAR ZIKF75S28 [image] $96.79 Price [image] Point ... Read more >>
March 22, 2022 * 6 posts * 33 views
KasperBPMC said: Hey guys, this is my first post. I just bought my 28th mustang, a 96 gt. It needed new fuel lines and brake lines. I am trying to see if anyone has any FACTORY pics of the fuel ... Read more >>
March 22, 2022 * 26 posts * 298 views
chrisp427 said: I have a 94GT with 1-7/8 port 3" stainless long tubes. I had them custom made , changing my starter is a breeze. But they costed $$$$ I'll list the guys info if your interested. Read more >>
March 22, 2022 * 5 posts * 80 views
Jakespeeds said: Thank you. Its probably headed that way. That is where I got everything from over the course of a couple of years. I was just trying the easy lazy way first. You never know with ... Read more >>
March 22, 2022 * 1 post * 18 views
Duff said: I'm thinking about going back closer to stock on my 95 302 cobra, right now it has it has a PowerDyne charger, chip, bigger injectors, methanol injection and a Walbro pump and ... Read more >>
March 22, 2022 * 1 post * 16 views
SN95Newsletter said: Click here to view on the web Highlighted posts Engine swap planning - analysis paralysis March 21, 2022 * 59 posts * 503 views Engine Swap Diff or trans noise!?! March 22, 2022 ... Read more >>
March 23, 2022 * 2 posts * 12 views
SN95_Project said: I tried the "bash the door to see if the motor starts again" trick and it hasn't worked. My son and I pulled the motor and tested it directly on the battery and it works fine in ... Read more >>
March 22, 2022 * 14 posts * 194 views
Duff said: American Muscle was $40 cheaper than Summit Racing, but IF there's a problem with my Summit order, Summit ships the replacement part as as soon as I call, I learned my lesson. Read more >>
March 22, 2022 * 146 posts * 2,056 views
Serfma said: Are you still having this issue Pedro? I have a 96 Cobra that I have replaced the pump multiple times on. Same issue: Everything is fine except WOT after around 3k+. Fuel pressure ... Read more >>
Continue reading...
RevJon
