Overheating Issue
ronis
My coolant bypass hose has ripped open I replaced the hose and still overheating. My thermostat is good and coolant levels is good also. Is there anything that I could look for to fix?
white95
Apex Junky
Admin
Prairieville, LA
You likely have air trapped in the system. You need to burp the air out.
This may be insightful:
R
ronis
I also noticed I had no heat and the temp would be a little above with the rad cap off but once cap on and pressurized temps went up. I noticed it was wet on my firewall/passenger seat foot well. It makes me also think it is a heater core. Going to bypass the heater core tmrw to see if that was also another issue.
R
ronis
I have two lines of some fluid underneath my dashboard on the firewall on the inside. No heat at all. Overheating before I changed the hose. I believe something with the heater core.
R
ronis
I have my heater hoses looped right now. I took out the thermostat for now. New Lower/Upper Radiator Hoses New Coolant Bypass Hose. I burped the system. Only thing left for me to think of would be the radiator.
R
ronis
The problem was the radiator and I have changed it. running no thermostat for about a day until I can take off the water neck. Temps are good so far but in jersey so the weather isn’t really warm.
R
ronis
I have two sn95 v6s one just for parts and ones the drift car. The parts one had a brand new one which i believe was replaced.
Pallgor
Sounds like there’s an air pocket. Common problem with todays motors. That’s why we use a pressurized coolant system to refill radiators at the shop
R
ronis
New Radiator fixed my problem threw the thermostat back in and all good.
Adfalenski
Pasquotank county, NC
I have a 2000 v6. Near the front of the intake manifold is a screw in hex sided riser that connects some coolant lines. It has a screw in plug in the very top which is also the highest point in the cooling system. I replaced the plug with a radiator drain valve. Now when I add coolant, I crack open the valve to bleed all of the trapped air/steam out of the cooling system and then close the valve.
Pallgor
I had an Oldsmobile that had 3.5 ( if I remember) that I did cooling system work and it took me 3 try’s to finally bleed the air out through the bleeders
RevJon
